Results 1 to 10 of 24
Thread: Arbor Press Modification
    Jul 2007
    West Michigan
    Default Arbor Press Modification
    Gentlemen,
    I implemented a modification on both of my arbor presses, an idea that I read about on this site. A while back, I had to broach a 5/16 keyway and my big press did OK as long as the lever was near horizontal. I had to use a series of shims to give me the proper angle on the lever. This modification allows the pinion gear to freewheel at the top of the stroke so the lever can be set to any angle that the teeth on the rack gear will allow.
    Feb 2012
    Crooked River Ranch, ORegon Near Redmond
    That's why they make arbor presses with ratcheting handles.
    Paul
    Great idea Brian! Thanks for the picture!
    Jul 2007
    West Michigan
    Quote Originally Posted by co_farmer
    Paul
    Wish mine had one.
    north bay area
    Re: Ratcheting handle:
    Easy- just adapt a used 3/4 inch drive ratchet with a longer handle.
    Jul 2007
    West Michigan
    Quote Originally Posted by sasquatch
    This modification cost me nothing except about an hour if my time. It also does not shorten the effective opening of the press. No material needed for an adapter either.
    Quote Originally Posted by bborr01
    But you can't turn over the ram so well.... One end of mine has a hole for insertable pins, the other does not. While I can put in a plate, I can also turn over the ram in case I want to push things that might burr up the hole but would be clumsy with a plate.
    SE Cheesehead land, WI
    I really like this mod.
    Very timely in that I was just griping about how the handle was in the wrong place for doing some press work this week.
    What did you use to carve out the clearance in the ram?
    Thanks for posting!
    Now on my To Do List.
    Jul 2007
    West Michigan
    Quote Originally Posted by T.Hoffman
    Thanks for posting!
    I used a boring head and took several small cuts of about .025 each. To set up the proper radius, I picked up the edge of the rack gear with an edgefinder then moved the table over half of the diameter of the pinion gear. Then I adjusted the boring bar so it just touched the rack. Easy mod and works well.
    Nov 2006
    Louisiana
    just slide the pinion out til it clears the rack, reposition the handle and press on.
