I have an 1980's MacMillan metal lathe and was wondering how to adjust the taper bearings. at the back and the front of the headstock there are two large flanges held on by 4 allen head bolts. the exterior of the flanges has car bog around it due to the fact that these flanges have never been taken off. Can someone please tell me how to go about getting to the bearings and how to adjust them![]()
My lathe is level and the belts are tight. The lathe hasnt had much use so it shouldnt be the motor. im purely trying to eliminate things that could be causing the vibration. How do you adjust the nuts and how tightly should you do it up to ensure the bearings are tight?
