Results 1 to 3 of 3
Thread: Blasting with alu oxide aka alucab
    Feb 2011
    South Africa
    Default Blasting with alu oxide aka alucab
    I just switched from blasting with silca sand to aluminum oxide due to the health
    Issues with silca sand.
    What is the dangers with long term alu oxide exposure, any advice from you guys that has experience with using it?
    Many thanks westline
    If you are using violence and it does not work, You are not using enough.
    Canada, Bc
    Less then the dangers of long term exposure to whatever you are sandblasting. Wear full protection!
    On the Oil Coast
    Quote Originally Posted by Westline
    The same,wear a respirator/positive pressure hood etc.
