I have a question for the old timers. I drilled a 1/2" hole through 3/4" polycarbonate sheet. The resultant ID was .507 - larger than expected from a .500" drill bit - maybe some wabble - but a useable dimension. Then I drilled the same 3/4" sheet lengthways (about 3") with the same bit and the hole ID is .496. So what happened? Did the lengthways bore cause the plastic to shrink? Very puzzling....
