Results 1 to 4 of 4
Thread: How to weld delrin gear
    Oct 2004
    Default How to weld delrin gear
    One of my neighbor bring me a small nylon or delrin gear. 2 parralel spirals .
    (.850dia .230bore .305 face)
    The gear had a crack from center to outside. What is the best method to glue it to the shaft.
    I can drill a hole to pin it in place. I suspect the torque will split it whitout glue.
    Jan 2006
    Indianapolis
    My experience with delrin or acetal and glue has been - it does not glue easily or well. YMMV
    Gary
    Dec 2011
    gulfport ms
    Delrin is nearly impossible to glue with any success. It is self lubricating and quite slippery to the touch. I have been making delrin bits for my scuba stuff for a while now, and from my research there is no easy way to glue it. I did see a thing on youtube where a guy had limited success. He used some type of etching acid, heated the delrin with a torch, then glued it up. Not sure what kind of forces on what he was doing but I'd guess for a gear they are pretty significant.
    Take a peek on youtube for "gluing delrin" and you should find it.
    FD
    Canada, Bc
    I think you would be better off drilling and taping it, if you can... Maybe drill and tap a 'side' plate on?
