Results 1 to 10 of 27
Thread: Hearing protectors recommendation
    Sep 2008
    Default Hearing protectors recommendation
    I suffer from Tinnitus, and I mean REALLY bad, so hearing protectors are a very important part of my safety gear but it seems none I have tried actually come close to their claimed rating in noise reduction. Back at the mines I had a set of military issue protectors that worked really well but those are long gone and now even the Peltor brand I have been using are starting to deteriorate from age and usage. These things (the Peltors) have a NRR of 30 and I suppose they will meet that IF the ear cups are squeezed tight with my hands so it's as if the spring headgear is not strong enough, a stronger spring would get uncomfortable however. What I am looking for is something like the military issue outfit I had, the ear cup pads were filled with some type of gel so the spring headgear did not have to hold them tightly to seal out the noise. Those things WORKED but I can't find anything close to that now, the odd thing is they were rated at NRR 30 also but were much better than the Peltor brand or any others I have tried, Currently I use foam ear plugs along with the Peltor earmuff type and while it works fairly well it does not work well enough for my lawn mower, or worse yet, the string trimmer. I am open to any suggestion for solving this problem and I would like some opinions on protectors before ordering a new set.
    Nov 1999
    SE OZ
    I don't have tinnitus but my wife has a severe case of it.
    Both our local Doctor (GP) and Audiologist said that there is not an effective (full?) cure and that it needs to be "got used to" and "put up with".
    My wife has certainly found that advice to be the case and she finds it quite distressing at times. She has very good hearing - even at her age (73).
    Most "distractions" etc. are of no use either.
    We have "peltor" ear muffs but while they work well for the mowers and severe/high shop noises they - and others before them - were of no real use for tinnitus.
    http://www.google.com.au/#hl=en&suge...w=1920&bih=785
    Canada, Bc
    What about active noise cancellation headphones? It seems to me they might be able to get better then 30db without having to seal to your head.
    Have you considered a haircut that would expose more of your face/head for the hearing protection to seal to? Or trying to move all the hair out of the way of the seal?
    Jul 2010
    Apex, NC
    Take a trip to you local gun store. They will have various ear protection gear there.
    I have about 4 pairs of shooters muffs and all we use them for is when my family is out mowing the lawn. My MTD riding mowers is damn loud. The muffs do a pretty good job of attenuating the noise.
    Walt
    Nov 1999
    SE OZ
    I have two new "manual" OHV "Honda" mowers - very quiet indeed and very good mowers too.
    The ride-on is a Hasquarna (sp?) zero turn mower with a single cylinder 19HP OHV B&S engine on it. It is a great mower. It is loud but the "Peltor" muffs sort that out very well too.
    Still no mention of a cure or anything for tinnitus though.
    Sep 2006
    Southwestern Ontario, Canada
    Did you say something.
    I can't hear you very well, I've got this ringing in my ears.
    Canada, Bc
    Quote Originally Posted by wb2vsj
    Walt
    Another good idea would be investing in a better muffler for the exhaust, or making one.
    Oct 2005
    Lower SE Michigan, USA
    Sep 2006
    DeWinton, Alberta, Canada.
    How about these ones
    3M™ Peltor™ Optime™ 105 Over-the-Head Earmuff Hearing Conservation H10A HV 10 EA/Case
    These are not the Peltors you commonly see.
    edited features
    Proprietary Twin-Cup™ design has soft, foam-filled earmuffs.
    Earcup pivot points that tilt for optimum comfort and efficiency.
    Liquid/foam filled earmuff cushions.
    They are @22 on Amazon
    Owensboro KY
    Quote Originally Posted by jdunmyer
    Hope that works as hearing loss & tinnitus constitute part of my VA disability. The last time I went to the audiologist (about 2 years ago) the only "cure" available was to sever the audio nerve (see: http://serendip.brynmawr.edu/exchange/node/2082).
    One of the ways to reduce the decibel level is to wear ear plugs and ear muffs. Kinda of a PITA, but it works.
