Results 1 to 7 of 7
Thread: Reseat CHUCK; Centrl Mach. T-586-HOW?
    May 2010
    Default Reseat CHUCK; Centrl Mach. T-586-HOW?
    The Quil keeps droping OUT!
    Jul 2008
    Uhh, There's just not enough information to answer this correctly. The machines quill? The tooling shank? A drill chuck dropping off the jacobs taper? Yes I know you did say quill, But I'm suspecting maybe the wrong terminology may have been used. If I'm wrong, I'll apologise for that assumption.
    We need a bit more information about exactly what's happening please.
    Pete
    May 2010
    Default droopy chuck ...
    Sorry, if I 'confused' the description.
    Chuck...wedged onto ?Spindle -> with an end, having been shaped Flat, (on 2 sides).
    This 2 part assembly gets inserted into the Drill...then, PRESUMABLY, gets twisted, (so the Flats can align with an internal slot; to drive rotation). Then 'jamed'; by action of jerkking the chuck down...driving it into a block of wood.
    All this is straight-foward, except; you drill 1 hole ... and it FALLS OUT!
    Is there a method for displaying CAD or 3d-files?
    Canada, Bc
    Quote Originally Posted by abi456
    Clean both the male and female tapers, any debris will cause them to be unable to mate.
    Insert and whack with a rubber mallet or with a regular hammer using a wooden block to protect the chuck.
    Do not use the quill feed to try and jam the chuck on.
    Do not whack excessively hard, You will only ruin something
    Check the arbor/spindle for dings/dents.
    Germany
    Do be sure to retract the jaws on the drill chuck before you give it a good whack with a rubber mallet!
    Basic Physics: Two particles of matter cannot occupy the same space at the same time!
    Jul 2008
    OK, Now were getting somewhere. I'll assume it's a standard Morse taper. That type of spindle holds due to a wedgeing action, And they will hold very tightly. BUT!!!! And it's already been mentioned, That "wedgeing" action requires both the male and female tapers to be spotless, And undamaged. Even dust a few thousands of an inch in diameter can and will reduce the holding power of a Morse taper. It's also possible that the internal taper may be damaged now due to I'd guess this problem happening multiple times.
    You may have to buy a new male taper, And just maybe very lightly ream the female taper with a designated Morse taper reamer. Try seating the taper as the others have suggested. If that doesn't fix the problem? Then my points above are going to cost you some money.
    Pete
    May 2010
    Default Slippy chuck,
    Black Moon;
    Thank you for the informative response.
    On my first try; sloppy cleaning, of just the spindle, made a significant difference, however, ultimately, failed. I plan, to return and meticuosly clean both male/female parts.
    The owner's manuel, (in mangled Chinese French), Tip; for pressing together - Drive them up, using the TABLE.
    Using those, I'll give it another go!
