Got another toy a couple months ago but due to getting the software I had not been able to play with it. Finally the Tech at Gamma Scientific was able to get me the right software for the machine.
Its a Gamma Scientific Radoma Spectroradiometer. Its a little different than normal spectrometers where it can be calibrated to measure intensity of light as well as the spectrum for analyzing things like cockpit displays to meet federal display guidelines. It also has a whole bunch of math routines and can figure things like color temperature and the like.
My plan is to use it to figure my tooling factor when I finally get around to making dielectric coatings in my vacuum system. The way that works is you pick a wavelength you want a filter for and make it. Measure the actual bandpass wavelength and use this info to correct the layer thicknesses for the filter.
This is the unit, A Gamma Scientific GS-1271 interface and GS-1251 Head with a RS-22 175w Xenon light source
Gamma Scientific Radoma Spectroradiometer by macona, on Flickr
This is a spectrum plot of a mercury-argon UV lamp. You can see the mercury lines on the left and the argon lines on the right. At turn-on the peaks are about the same but as the lamp warms out the mercury lines are quickly overshadowed.
Hg-Ar lamp, warm by macona, on Flickr
