wow 10 responses already, thank you all so much, let me try to respond to these suggestions:
Originally Posted by
Lew Hartswick
If youre cutting 4 Acres with 6" diameter wheels you need a bigger
mower.
...Lew...
what do you mean by this? this are the mower wheels, its a belly mounted 60" wide deck....short of a brush hog or similar 3 pt implement I can't go any bigger.
scotplant
could you not remove chuck jaws and turn them round and hold it with the stepped side??
Tom..
Could you clarify what you mean by the "stepped side"? when I pull the chuck, I have a 4 hole backer plate (with reg boss)....I do not own a faceplate at this time, but wouldn't mind an excuse to make one.
Before I realized my chuck wont handle it, I had planed on making nice hardy arbor out of some 1-1.5 cr I have...make a nice threaded shoulder at the end and maybe a second for the tail end. I have used this method many times to do my "normal" work(~1-2" stock) The trouble I have is putting the center hole it without the lathe. Yes I have a drill press, put have never had much luck in accurately locating the center & if I miss then I am starting with an irregular cut at 6" and I worry about the machine handling that . My drill press probably needs a good tramming if I am to go in that direction.
Carld
I have a 13" lathe and turn 8" work as long as it's not to long.
If your going to make wheels out of 6" stock are you going to band saw them to 2" disc's? If so just chuck one up as straight as possible and face one side, flip it face the other side and bore the hole for the bushing or bearings.
I don't see a real problem doing the disc's. It's a mower and the OD concentricity is not that important.
yes I plan on a band saw to slice them, but was thinking I would take the od down to true before than slice, but I still cant hold it for that first turning. My plan was similar to bore out bearing cups for ball bearings. and I know concentricity is not crucial, but I would like to do it well to expand my skill set.
garagemark
Here's a dumb question: Why true up the 6" CR in the first place? These are not high speed wheels. Why not just cut your 2" slices, center drill them and bolt em on? Unless you need to cut bearing pockets or something else, I can't see the need for perfect deck wheels. 2" Slabs will last forever, or until the center hole wears out. Then simply sleeve them again and again.
Mark
my father suggested this....I am putting bearings it the wheels (2per wheel) & making new axle bolts to mount them. This is overkill, but the old steel on steel bearing arrangement led to the shafts looking like irregular cams and the bores to be nearly 0.250 over sized....it took about 20 years, for this wear to occur but I don't want to do it again, ever.
lakeside53
I interpreted the OP question as a holding for a facing/boring operation.
Surely the 16 inch lathe can handle the stock if the jaws are turned around. My 14 with and 8 inch chuck can do it in a heartbeat. I've used expanding mandrels where the faces and OD of 7 inch stock needed to be done in one setup.
I thought so to, unfortunate its a 16" swing with a 5" chuck...would love to get a big 4 jaw in the future, just not in the budget right now. I cant reverse the jaws, but I have 2 sets, neither are big enough.
Dieseldoctor
I think what the OP is wanting, since these seem to be anti-scalp wheels for a mower deck, is to crown the outside diameter so they don't tear up the grass while turning with wheels carrying some load. I would use a mandrel the size of the mounting bolt as previously suggested or drill a couple holes though web of wheels to bolt to faceplate also previously suggested.
this is correct, although I am planning to create a lip on either side to retain some rubber treads I'm making to give a little cushion to the wheels & keep the power coating on the entire chuck of steel....rust always worries me on agriculture equipment.
Given the suggestions, I am inclined to go with the mandrel method as I intended, but starting that hole on the drill press...something I never do, because I have a lathe, could you all give me some advice on getting that center hole accurate? I know I can turn it true no matter where the hole is, but I'de like to keep as much material as possible. thanks again everyone!
"it is no measure of mental health to be well adjusted to a profoundly sick society." -- krishnamurti
"look deep into nature, and then you will understand everything better." -- albert einstien
"any intelligent fool can make things bigger and more complex...It takes a touch of genius - and a lot of courage to move in the opposite direction."
