After wanting a lathe for a long time i made some enquiries and found one, after a small amount of bartering i swaped a piller drill for it - bargain i thought. it is a Colchester Master 2500, the lathe is in excelent condition and only needed a little clean and a few small parts to make it work.
Now, after buying a manual and looking for parts i find i can't get alot of the things i thought would be available for this lathe, on smaller lathes you can get Vertical slides, slotted cross slides and other things to make the lathe more useable.
Are there things availble for this make and model of lathe so i can use it for more than just turning?
Any comments are all greatfully accepted.
