Most modern boiler controls are likely electic/electronic however much field hardware maybe pnuematic......the demands maybe high depending on the amount of equipment BUT it was likely sized right initially and the risk management stuff will probably provide you with your golden child. Our control air compressors are 4 pumps 44cfm each driven by 2 motors in an opposed arrangement, been running 24/7 since 1985, they've probably had 2 light freshenings.....I found a deal on a smaller Devilbiss 2 stage pump that was a control compressor for $40, they said it would never shutoff so bought a new one and when that wouldn't shutoff they started looking for the offending leaks......
