Results 1 to 2 of 2
Thread: Monarch 14C Pulley Speed?
    Oct 2008
    Question Monarch 14C Pulley Speed?
    Anyone here know the correct RPM for the clutch pulley on a 1946 14C? The existing motor RPM isn't legible, and voltage is 440 only. I'm replacing it with a 230V 5HP 1730RPM 3PH motor and Polyspeed phase converter VFD. Also not assuming the current motor pulley is correct. I know the VFD will allow me to adjust the speed, but I'd like to run it at 60HZ at the intended original RPM.
    Oct 2008
    Found this while cleaning the speed setting plate.
