Replace the transformer today. The original was wired 110v input with 24v output 100VA. The replacement is 120V input 25.6v output 2amps, so +/-50VA. The original transformer burnt up when it was wired to 240v (see other posts).
Everything works up to the point of starting the lathe. It starts and runs for about 3 seconds, then the relay releases and it stops.
The lathe has 3 relays/contactors (not sure of the correct name), 2 C16G's and 1 C11G. The C16G have 10 contacts, plus one at the base that is 24v. The C11G activates when I turn the machine on. When I push the start button, the left C16G relay activates for about 3 seconds and drops out. All 3 relays have a push to test button. If I push the test button on the left relay it runs as long as I keep it depressed. If I push the C16G on the right it runs in the opposite direction until I release it. There are no controls on the front of the machine to reverse spindle direction??? There is a control to reverse the lead screw. Would it also reverse the spindle at the same time?
My main question is what is causing the relay, contactor, coil, solinoid whatever it is called to drop out after 3-5 seconds? Does it have a primary/secondary winding and the primary is pulling it in and then the secondary is "bad" causing it to drop, when the primary releases?
Do you think the transformer is too small, and doesn't have enough current to operate everything? I've got a 20amp VariAC that I could temporary up test if necessary?
Any thoughts or suggestions are appreciated.
thanks,
Ken
, but finally found it thanks to Dave.
