Gentlemen--I have a Harig Surface Grinder that I am restoring and the graduated dial could use a bit of work. It's an aluminum ring that rotates on the wheel, not too unlike that used on a mill or lathe. I would like to blacken up the engraved numbers and tick marks and I know you guys know the secret formula. Could you share?
In advance thanks!
