Results 1 to 10 of 26
Thread: Need Opinions
    Default Need Opinions
    I have decent mechanical skills, build AR 15 rifles, fix, modify them and would like to graduate to making other firearms-related items, notably a 80% lower in a 100% receiver.
    So I am looking to make lowers, cut/thread barrels and perhaps try my hand at making a railed HG.
    I was looking at this machine seller
    The 80% lowers can be seen here
    Not looking to make lowers/barrels for sale, but simply for my own use.
    Thanks in advance.
    Sep 2010
    Southern California
    Hi.
    I'm not sure what you are asking. Are you wondering if Smithy makes machines that would be good to use for your stated goals?
    Well, yes, how up to the task are their machines as related to my stated goals?
    Any general opinion on the gear they sell or the customer service aspect?
    Just like anyone, I am trying to get into some basic machine work without breaking the bank, but I want something that won't struggle to keep up with what I aim to machine.
    I already have a garage full of handy things, but the wife would rather her car be in there, so the small footprint was a definite plus.
    Complete 80% lowers
    Cut/thread barrels
    Make my own railed handguards
    Make smaller items, i.e. flash hiders, maybe some (AR 15) bolts.
    If YOU had 1,000 - $2,000 to spend, what would YOU buy, or would you wait and save to buy something better?
    Thanks in advance.
    Surrey BC Canada
    Not having a clue what you are trying to make, I can't help much.
    We do have a sub forum on gun smithing here. You might get batter answer there.
    if you have the skills a file and a hacksaw is all you need to make anything.
    Dave
    Default Smithy
    From what I've heard Smithy has useable equipment and good service. I would go with the separate lathe and mill rather than a combo set. That would take only a little more room than the combo and be much more desirable. I have no first hand experience with this brand.
    Jun 2006
    2 miles from the London Bridge, 43 miles from Swansea
    Happiness is a sharp tool.
    Jul 2003
    Vici, Ok.
    My advice would be to google the 3 in 1 machines, you should get a lot of reading. I can't count the amount of times this question has came up over the yrs. on various forums. Most will tell you the lathe part is not that bad, the mill not so good, and it is a pain to be changing setups ever little bit. Occasionally someone will show some very good work, and claim they are perfectly happy with theirs. In the end it is your choice.
    James
    Cheyenne Wyo
    I don't know much about AR-15's, and even less about combo machines. But I have threaded and chambered quite a few replacement barrels. The best luck I've had is with the barrel through the headstock on a fairly heavy lathe. What you don't want is chatter to get started, and since a chamber reamer is cutting along its entire length, it REALLY is prone to start chattering. So spiral fluted reamers, working with the chamber up close to the headstock, on a nice sturdy lathe, are all good things (in my book)
    I'm here hoping to advancify my smartitude.
    Quote Originally Posted by dewat
    Sounds good, but WTF is with the registration feature?
    You did not answer the verification questions correctly.
    Builders help Builders
    ideas become reality
    They are the only two mottos and the graphic is letters, DUH!
    Some boards are a PITA to register.
    I had to send an email after two weeks on this one to get activated.
    You'd think I was getting access to NORAD launch codes.
    I'll try from home later . . . can't comprehend what the issue is.
    Quote Originally Posted by gizmo2
    Good advice. I knew nada about AR 15s in 2007, in 2012, I know nothing about machining, in 1965 I was just learning to tie my shoes. Life - learning, for me anyway.
