Results 1 to 10 of 24
Thread: LeBlond Regal follow rest?
    SE Cheesehead land, WI
    Default LeBlond Regal follow rest?
    My LeBlond Regal from the mid-60's did not come with a follow rest.
    I need to thread a length of smaller dia rod, tough to do with no follow rest....
    When looking at my lathe, there are no mounting holes on the left side where a normal follow bolts on. There are mounting holes on the right side of the saddle.
    I'm guessing that the original follow was quite a piece, mounted on the right side and reached over to be near where your cutting tool was.
    I've never seen one, but I called LeBlond to see just by chance if they were still available. If they had one, I knew the price would be high from my buying a couple small parts from them before.
    They do still have this follow rest available.
    ....for the low, low price of $2469.
    Anyone ever see, or have this follow rest for a LeBlond Regal (or willing to part with one)?
    If you have one, can you take a pic of it?
    Here's my lathe before I cleaned her all up to give you an idea of the vintage of this Regal.
    You can see the two mounting holes on the right side:
    Feb 2010
    Spokane
    It is tough to do even with a follow rest.
    I am sure you have already considered using a die?
    Dave
    Actually this little project for work isn't really a true "threading", but rather a .100" rounded groove at 7tpi with a .230 minor diameter in some 3/8 rod...... and it has to be a left-handed thread of course.
    They use it to make coils of some sort of .095" OD plastic tubing for fluidics work. They spiral on the tubing and heat it with a heat gun, when it cools they have their nice spiral.
    I have a GrizG4003 lathe as well which does have a follow rest, but the Griz can't do left hand threads as it is now.
    Apr 2011
    SW Michigan
    Why don't you have Leblond send a drawing to you. I think I have one for a 17" but my lathe is the one before yours.
    The richest man hasn't the most but needs the least.
    Keep Calm and carry Guns! Old Friend of Old Iron.
    Always Plan for the Future but Live for the Moment!
    Feb 2010
    Spokane
    Oh, that!
    Is this something that has been made before? What length?
    Have you investigated adding an idler in the change gears on the Grizzly? Just a thought.
    Dave
    Jul 2008
    Northeast Atlanta
    I have wondered why LeBlond didn't make the follower to reach further to the left, making it easier to support near the left end of the carriage. If I were you, I'd make one.
    HTH,
    Greg
    Quote Originally Posted by rmw
    [IMG]
    Greg
    Greg,
    thanks for the pics!! I was thinking that it would reach further to the left....
    That offset only looks to be a couple of inches?
    hmmm, this may be a new project in the making for me.
    About 7-8" worth of threading. I made one earlier in the week on the Grizzly with the follow rest with a RH thread, turned out nice.
    That's when they came back and said that this was great, but needed to be a LH thread (which they did not tell me in the first place)......
    ....information that would have been nice to know before I started.
    I haven't investigated an idler on the Griz yet. I know some have done it, but think I'd rather put that time/effort into the LeBlond.
    Sep 2003
    Louisville, KY
    The Nov/Dec 2011 issue of HSM has an article "User Friendly Follow Rest" that has a few more details than the following pictures of the last one I built after the article was submitted.
    Harry
    Hey Harry
    That follow rest is good looking.... and most practical design I've seen.
    Thanks for the PIXS.
    Robbie
    Robbie
    Quote Originally Posted by T.Hoffman
    At 5 times the price that it should be...the same with Cincinnatti,just too much for parts.
    I have 7 lathes in my shop.. Mauser, Lodge & Shipley,Hardinge and Standard Modern lathe
    Best when you need stuff is Standard Modern Lathe ..you won't get taken advantage of.
    Robbie
    Robbie
