Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: OT: computer password problem
    Jan 2010
    Germany
    Default OT: computer password problem
    Today my computer decided to not accept my windows user password. I tried rebooting several times. I took the battery out of the motherboard to try and reset the cmos. I went online to look for a solution but didn't find one that worked.
    So anyone have anything they would share with me as to what I can do to get access to my files on my C drive?
    Basic Physics: Two particles of matter cannot occupy the same space at the same time!
    Make sure Caps Lock is off and Num Lock is on.
    If that fails, use this: http://pogostick.net/~pnh/ntpasswd/
    Dec 2010
    Finland
    At a friends computer, install a Linux on a USB stick and boot your computer from that. Then you are able to browse your hard drive and copy everything you need, just in case.
    Other option is to remove the hard drive and install it in another computer as a slave drive and access it that way.
    No passwords required, unless you have encrypted drive.
    Apr 2011
    SW Michigan
    Probably overloaded it with Volvo pics!
    The richest man hasn't the most but needs the least.
    Keep Calm and carry Guns! Old Friend of Old Iron.
    Always Plan for the Future but Live for the Moment!
    Research shows all violent criminals have the same disorder:
    ACUTE LEAD DEFICIENCY!
    Mar 2008
    Kent, U.K.
    Quote Originally Posted by Black Forest
    Log on as USER: Administrator, and leave the password blank, since that is the default for windows.
    Aug 2002
    Albuquerque
    If it's a personal computer and only used by you then it serves you right for ever using a password. :-) The fewer things that get put
    on a computer the fewer things to go wrong. :-)
    ...Lew...
    Apr 2009
    Springfield, Mass
    Quote Originally Posted by hsm'er
    doesn't apply to a desktop but on a LT make sure num lock is OFF!
    Make SURE your username is correct
    Try another keyboard. and / or watch to see if each keypress causes ONE new dot. As a quick check try entering your password as a user name to view the keyboard output
    if a USB keyboard, try a different port. Note that windows may take a few minutes to find keyboard on a different port
    I like to use a password even if I am the only one on the machine. and Administrator should NEVER have a blank password. On Vista and above the administrator account doesn't exist by default
    there are Linux boot cd's that can be used to reset the windows password; or as a previous poster mentioned you can copy files IF YOU DID NOT SPECIFY AN ENCRYPTED FILE SYSTEM
  8. #8
    Default Bootable Linux
    As has already been mentioned, use a bootable cd/dvd to change the admin password. The ISO will be about 10MB and the entire change process will take about 60sec (if that).
    Of course, if it's the only computer you have, the burning process will be a little complicated...
  9. #9
    Jan 2010
    Germany
    Hey Lew, did anyone ever tell you that you are a Ähole! Well now they have! I don't wish you any serious harm but being constipated for a week would seem justified.
    There are many reasons to have a password on a sole user personal computer.
  10. #10
    Jan 2010
    Germany
    I got it fixed. I ran a linux based registry editor and removed the password. Thank you for your help.
