Results 1 to 2 of 2
Thread: Got the 300 Black Out back
    Apr 2009
    Columbus Texas
    Default Got the 300 Black Out back
    Well got the 300BO back from palmetto State Armory. No improvement in accuracy. Here is a pic of the target after we moved it to 30yds. That’s a 2” wide piece of duct tape. They say they use machine gun steel for the barrel. And that is what I got “SPRAY AND PRAY”…
    And no scope adjustments.
    Montezuma, IA
    Check the twist rate on the barrel to see if it's close to being as advertised. Also slug the bore and take another look at the crown and the throat. If you want to tear it down, pull the gas tube and re-torque the barrel nut. Double check your sight mounts.
    David
    David Kaiser
    Montezuma, IA
