Results 1 to 5 of 5
Thread: Steel Valve Body Advice Please
    Sep 2004
    Default Steel Valve Body Advice Please
    I have been repairing some Cast Steel Valve bodies. I grind out the Crack ,, degrease and preheat a Little bit with a torch them hit it with a Mig Gun. Afterwards the weld looks good but when cooled down it has again a crack in it where the crack in the cast steel housing was. Any Hints tips Much appreciated Thanx guys Mike
    Jan 2002
    Toronto, Ontario
    Are you sure they are steel??
    Nov 2004
    Are these Tranny valve bodies??? Like powerglide??? They are cast iron if they are....better off silver solder/brazing them....Shawn
    Sep 2004
    Default Yes
    Steel Valve Castings some weigh quite a bit. Used in Plants foor air and steam.
    Jul 2002
    Did you try and drill a hole at each end of the crack?
    What about a blanket or something to keep the welded area from cooling down too fast?
    Post weld heat?
