Results 1 to 2 of 2
Thread: Birmingham CT 1440 G found the problem
    Apr 2012
    Western central Fl
    Default Birmingham CT 1440 G found the problem
    I finally did some more testing this weekend using a wiring diagram for a "Grizzly" as a guide. Tested the switch, jog, e-stop button, and everything looked good. That led to the fwd/rev switches actuated by the linkage and cam from the apron lever. Thought I had found the problem then realized one was installed "backwards" to the other. Still no joy. Then I thought possibly the cam wasn't completely opening the switch. I decided to switch the wires on the wire bus from the fwd/rev switches to test the cam. The cam was releasing the switch, but reversing the wires reversed the relays for fwd/rev. The same relay was sticking. That meant it had to be a mechanical issue with the relay instead of a wiring issue.
    I searched the internet several times this weekend and could not find a C-16G relay/contactor. I finally remembered that Matt at Quality Machine Tools had said to call him back if I found the faulty parts. Just got off the phone ordering a "generic" replacement.
    Finally I'll be able to shut down my lathe when I want to instead of when it wants to.
    Thanks for all the help and suggestions,
    Ken
    north bay area
    Great you got the problem sorted out!!
    Now YOU have complete control again!!
