Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Using up every last bit of scrap
    Jan 2008
    Mouldy, Or
    Quote Originally Posted by Frank46
    Just curious but wouldn't delrin make decent supports for a steady rest? As a replacement for the brass/bronze fingers? Thanks, Frank
    I don't think they would take the heat and friction for very long
    Tom C
    ... nice weather eh?
    Dec 2010
    Finland
    Friction will soon melt them down and anything not-ground will eat them up pretty soon and badly.
    But for some sensitive/delicate/light work and with a lubricant they might work.
    Apr 2009
    I have a travelling steady that was supplied with my c1907 Drummond lathe which had wooden inserts instead of fingers.
    Albuquerque
    Quote Originally Posted by The Artful Bodger
    Wooden? I hope that were either Ebony or Lignum Vitae. :-)
    ...Lew...
    Apr 2009
    Quote Originally Posted by Lew Hartswick
    ...Lew...
    I think it was a block of whatever was available. Presumably one was expected to mount a block in the holder (two blocks actually) and drill a hole through to match the diameter of the work. No doubt it worked quite well.
  6. #16
    Feb 2012
    Cleveland
    Default There's no such thing as scrap...
    You just haven't found a small enough project yet.
    A few random comments here: While I like McMaster Carr for information and service their prices on many things (like plastics) is just painful. I do much better on a lot of things on ebay.
    Frank: The material is WAY to soft for the application you suggested. If the pressure didn't kill it the heat would.
    Allans Rule: Anything worth doing is going to be a pain in the butt.
  7. #17
    Feb 2007
    I use collets to get the most out of material,especially material like ivory. With a slight undercut on a stepped out collet that I have turned a specific diameter in to hold a particular project,I can grip and turn ivory using only 1/32" of material. The step I turn has a dovetail effect on grabbing the ivory.
