Originally Posted by
J Tiers
And I'm "pretty sure", after actually reading it years ago, that you'd do about as well by just oiling the machine and starting to use it.....
<snip>
Plus, I challenge ANYONE to explain why and how making dozens of delicate measurements with an indicator (every newbie has lots of THOSE, and knows all about using them, right?) is simpler and easier than making TWO simple micrometer measurements per trial with the "TCT" (two collars test).
Especially when "TCT" actually tests the results you DO get, not "the potential error you might get if these delicate measurements are ALL exactly correct and everything works out just exactly right".
<snip>
