I have a control box from a friend's John Deere hay baler with a broken resistor, the box was physically damaged. The only parts we need to fix this thing is a couple of Bosch type relays which are easy to find but one of them was pushed down onto a resistor and ruined it also. This thing is a .03 Ohm 10 Watt resistor with a 5% tolerance. Been searching the net and can't come up with a thing, found a few .03 Ohm but only in 1, 1/2 and 2 Watts. Any suggestions on where to find something like this or some type of substitute?
