Results 1 to 10 of 23
Thread: OT: help with low voltage regulation
    Mar 2002
    webster, ma
    Default OT: help with low voltage regulation
    I have two old impulse driven clocks for which the battey is either no longer available, or stupidly priced. What I'd like to do is to place either a couple of C or AA batteries in parallel and regulate the voltage down to say, 1.2 or so volts.
    Any suggestions on how to do this?
    Thanks.
    gvasale
    Surrey BC Canada
    A quick search of Digikey shows options at that voltage range.
    Need more details but have a look at this one.
    http://www.digikey.ca/product-detail...7-1-ND/2339543
    Dave
    Mar 2002
    webster, ma
    That one shows voltage adjustable to .9 volts. A little short on the voltage...
    gvasale
    Jan 2002
    Western, Kentucky
    Here's one:
    http://www.mouser.com/ProductDetail/...W0fIekSjDZk%3d
    You will have to bump up your input voltage to 4.2 volts and it has an max output current of 100mA.
    Here is the data sheet for it: http://www.ti.com/lit/ds/symlink/lm317l.pdf/
    "The truth is incontrovertible, malice may attack it, ignorance may deride it, but in the end; there it is." Winston Churchill
    Dec 2005
    Minnesota
    Why does the voltage need to be regulated? You could use a NiCd cell to get 1.2V, parallel a few if you need more current.
    [edit: grammar]
    Jan 2007
    Los Angeles Ca. area
    Voltage regulators all drop some voltage in the process. To get 1.2 volts, you will need more than the 1.5 V that "C" cells provide. Putting 2 in series would give 3 V and may be enough to regulate down. Since rechargable batteries are already at 1.2 V nominal. Wouldn't that be easier?
    Ernie
    Looks like I was too slow in typing a reply.
    Mar 2009
    Sweden
    http://www.digikey.com/product-detai...ASCT-ND/969504
    Might be an option. Include LDO in the search terms to get a low drop out regulator, the one above states 0,3v typical dropout@ 2A.
    Mar 2002
    webster, ma
    I'm trying to do this with a small package. It used to have a battery pack about the size of 4 AA batterys. The object is to have something with as constant curve as possible.
    I used to use ni-cads years ago but not for this purpose. They self discharge and I've always found it difficult to find high quality batterys.
    AAs are cheap, and always available and make it un necessary to switch out batterys like if a rechargable is used.
    It is also time consuming to have to try and constantly re regulate the clock for the change in voltage when the battery us new and after some length of service.
    This not a quartz movement.
    gvasale
    Nov 2009
    Ontario
    Quote Originally Posted by gvasale
    Dave found you a viable option.
    It's Low Drop Out and will regulate down to .9V.
    That is a minimum, it will regulate fine at 1.2 as you specified with a 1.5V input.
    However, I suspect you'll find this is non-trivial and this solution will eat batteries although it will work.
    If you buy crap, be prepared to re-design and fix it.
    Mar 2002
    webster, ma
    Motor... Is there a better solution which doesn't "eat" batteries?
    gvasale
