Results 1 to 6 of 6
Thread: Is there a long taper spindle mount smaller than L-00?
    Nov 2002
    San Francisco
    Default Is there a long taper spindle mount smaller than L-00?
    A while back I bought a four jaw chuck on Ebay that was advertised as having an L-00 mount. When i got it, it cetainly looked like an L00 mount, but when i tried to fir it, I found that the key in my spindle nose wouldn't fit the keyway in the chuck. As I looked closer, I saw that the diameter of the threads is just a bit smaller than my L-00 mount chucks that I have on hand, and the taper bore is a little bit smaller as well. I have searched the web for L-000 mount but have come up with nothing. Can anyone shed some light on this? If measurements are needed, I can get them this evening when i get home.
    Nov 1999
    SE OZ
    Mar 2007
    Rivett had proprietary taper very similar to L-00, however I'm not sure if its smaller or bigger then L-00, will have to go and measure.
    Aug 2011
    Central Virginia, USA
    1/4 inch wide key? I think that's a Rivett 918. About 1/3 of the way down this page:
    http://www.lathes.co.uk/rivett/page8.html
    allan
    Nov 2002
    San Francisco
    Thanks fellas!
    The Back of the 4-jaw in this picture looks just like the back of the 4-jaw I bought.
    So I went downstairs and took a look and sure enough, it says RIVETT right on the face of the chuck. I wonder if someone has a RIVETT lathe they need a chuck for? I really like the chuck itself as it is quite shallow, and would be nice for barrel work through the spindle.
    Default 4 Jaw Rivett 918
    I have a couple of Rivett lathes including a 918, and would be interested in acquiring a 4 jaw for it. I've had somewhat the opposite of your experience, buying a "Rivett" backplate on eBay only to find it was an L00 instead.
