Results 1 to 9 of 9
Thread: Help with Marv Klotz software
    Apr 2008
    winnipeg/manitoba
    Default Help with Marv Klotz software
    Does anyone have a workaround for running the software files that Marv posts on his website? Specifically using Windows 7? I'm not even sure if I can get a DOS prompt with Windows7 ?! Mr. Klotz has generated some wonderful bits o' software, and I'd hate to have to abandon them due to my ignorance.
    Jul 2002
    Central Western NSW, Australia
    Yes, there is a way of doing that - probably best to ask Marv directly.
    Tel
    Feb 2006
    Harwich,Essex,UK
    May 2011
    Dosbox works on win 7 real nice. Easy to download and cheap.....FREE
    Pete
    Los Angeles, CA, USA
    Apparently you didn't bother to read the first paragraph of the Introduction section on the webpage.
    Regards, Marv
    I hadn't heard of DOSBox prior, but there's a Mac version which means Marv's math tools will run "native" on the Mac. It also means all the old DOS era tools I wrote in assembler will probably work, too.
    Apr 2008
    winnipeg/manitoba
    Quote Originally Posted by mklotz
    OUCH!! I thought that I'd read the opening paragraphs, I even went back and re-read!!! Now I have to find out how you safely remove a petard....
    Beaumont, TX
    Quote Originally Posted by millwrong
    I am not sure which of Marv's programs you are talking about, but you can get a DOS prompt in Windows 7. Just click on the Windows meatball at the left side of the Taskbar and the DOS window/Command Prompt is about the fourth item down.
    I am not implying that there is not a problem running some legacy programs; just pointing out that there is a DOS/Command Prompt window available.
    In 64-bit Win7 this is what you get when you run an older MSDOS (16-bit) binary in a terminal window. Hence the need for a DOS runner tool like DOSBox.
