Results 1 to 10 of 14
Thread: Stick welding with TIG unit??
    May 2012
    Default Stick welding with TIG unit??
    Seems to me I could use arc welding rod in the TIG torch, if I want to do some stick welding, with no Argon. Is this a viable idea? I have a Miller Diversion 165.
    Dec 2008
    N.E. oHIo
    Quote Originally Posted by xs hedspace
    NO, it is NOT a viable idea.
    Rex
    Apr 2011
    Boise, Idaho
    Default Possibly
    You can TIG weld using a DC stick welder as the power supply. I have an air cooled TIG torch and have done it numerous times using a Miller AC/DC buzz box. Not being able to easily control the current makes the TIG operation a bit tricky with this set up. For the reverse you would need to replace the TIG torch with an stick electrode holder.
    I have been looking at possibly buying a TIG unit so I have been looking at specifications for a number of makes and models. Quite often different models of TIG welders are also sold as stick welders. I do not know if the Miller Diversion 165 has that capability. The power supply for a TIG welder is a constant current source device which is the same type of supply used for a stick welder. MIG uses a constant voltage supply so attempting to TIG or stick weld with a constant voltage supply probably would not work to any degree of satisfaction.
    The Diversion 165 has a number of modifications and enhancements to the basic constant current supply that apparently improve the TIG welding experience. Stick welding may or may not be improved by these enhancements. I would look at the manufactures specifications for your Miller machine to see if stick welding is supported. Perhaps a call or email to the supplier would answer that question.
    Beaverton, OR
    Technically, you could do it but I wouldn't. The electrode holders are intended to have gas passing over them wile running to cool that and the cable inside the hose. So you would end up using a lot of gas. If you had a known clean and oil free supply of air you could probably run that in place of the argon to cool it.
    Mar 2011
    Iowa
    No, you fooked yourself in the stick welding department when you bought the Diversion instead of a syncrowave. The diversion is a TIG only machine.
    Dual use units DO exist.....
    The Lincoln 175 at work can be set for either, all you do is plug in a stick setup and go, flipping the switch to "stick". AC, DC all the same options are available, just no gas, no HF arc starter.
    We just did it a day or two back.
    Mar 2010
    My Miller Maxstar 151 is TIG or stick. Just flip a switch. But it is DC only.
    RWO
    Aug 2008
    Missouri, USA
    Unplug TIG torch cable - plug in stinger cable - push mode button - start burning rods.
    Jun 2006
    Austin, Texas
    Quote Originally Posted by Highpower
    +1. Most modern (last 15 years) TIG machines come with a stinger for stick welding. I use mine a lot on my Thermal Arc Pro Wave -- pretty amazing stick welding on a little attache-sized inverter unit
    Oct 2010
    Nice Machine! Ring email millers help line for that particular machine I use an older Miller CY50 HF start & run AC, DC+,DC- It can run a spoolmatic MIG gun if I lock off the AC side a dam good all round machine.
