Results 1 to 8 of 8
Thread: Change gear ID?
    Apr 2012
    Medford Oregon USA
    Default Change gear ID?
    I bought my Boxford lathe from a guy who bought it at an auction and some of the change gears don't appear to be for a Boxford. Its ok as Boxford gears seem to be pretty common and the majority are correct.
    These three are clearly much bigger though with a width of about 0.625 inches and bore of 0.80 inches. Anyone have a clue as to what they fit?
    Nov 1999
    SE OZ
    0.625" is 15.875mm - say 16mm
    0.80" = 20.32mm - say 20mm
    The gears could be metric - MOD1 - where the OD of the 55 tooth centre gear would be 55 + 2 = 57mm
    If that is the case, the pressure angle would probably be 20 degrees
    For an "inch" gear the pitch circle diameter is Number of teeth/Pitch Diameter and as 55mm = 2.165" assume 2" in which case DP = 55/2= 27.5
    I'd have expected a whole number for the DP but "1/2 numbers" are in use as well.
    Its a wild-ar$ed guess but at least its a start.
    Having the OD would help.
    Apr 2012
    Medford Oregon USA
    Thank you for the guess. The OD of the 55 tooth is 91.80mm/3.615". The 64 tooth in just over 4"/102.85mm. The 56 tooth is almost the same size as the 55 tooth gear. What ever machine they came off of, these gears are big!
    Nov 1999
    SE OZ
    Thanks for the extra info - appreciated.
    I was way out.
    For the 64 tooth gear where as a first guess the PCD is 4 ":
    DP = 64/4 = 16
    OD = (no. teeth + 2)/Pitch circle diam (PCD) = 4.125"
    As the gear theOP has has a diameter of 4.05" (102.85mm) and the difference is 4.125 - 4.05 = 0.075" I'd pretty much settle for the gear being 16DP.
    I will check again for metric later.
    Apr 2012
    Medford Oregon USA
    Thank you for the help! I think the gears are 16 dp as they all seem to average very close to that. I remeasured the bore, it is closest to 13/16" but it will be a snug fit.
    Nov 1999
    SE OZ
    I re-did the 64 tooth gear in metric and assumed the pitch circle diameter to be 100mm and the gear to be MOD 1.5
    But PCD = 64 x 1.5 = 96 and OD = 96 + (2 x 1.50) = 96 + 3 = 96mm
    That is too far below the actual PCD of 102.85mm - so disregard modular gearing.
    I would just about bet that the pressure angle is 20 degrees.
    Nov 1999
    SE OZ
    I re-did the calculations again as I made an error as regards the addendum - it is fixed now.
    DP = 64/4 = 16
    Addendum = 1/DP = 1/64
    OD = PCD + (2 x addendum) = 4 + (2 x 1/64) = 4 + 2/64 = 4.031"
    As the gear the OP has has a diameter of 4.05" (102.85mm) and the difference is 4.05 - 4.03 = 0.02" I'd pretty much settle for the gear being 16DP.
    Apr 2012
    Medford Oregon USA
    OK thank you for the help.
