Page 3 of 9 FirstFirst 12345 ... LastLast
Results 21 to 30 of 84
Thread: Starter Ring Gear Question
  1. #21
    Quote Originally Posted by aboard_epsilon
    ive got a spare starter that has a longer pinion on it ..but still the same amount of travel
    the originals starters pinion looks unworn ..the wear has only taken place on the ring gear.
    well... we will see ..put the old one back on .......if ok for a period of time ......it will be left on ....if not will swap for the spare one ..
    spare one will have to be taken apart cleaned up ...its an unknown bought from car boot sale for £1
    all the best..markj,
    Holy crap is that the original ???
    Very possible this could be your entire problemo...
  2. #22
    Oct 2004
    Prestatyn, North-Wales
    to rotate the flywheel to a different position ..requires me to take the box out ........when the time comes to do that .....i will replace the ring gear..
    all the best.markj
  3. #23
    No --- I said just get the starter properly fixed and then run it ---- but if it ever comes out then you might as well rotate things,
    You most likely have enough ring gear teeth to scrap your car....
    What pic above is the original? and what one were you using ?
  4. #24
    Scotland.
    Mr Sleepy and Terry G are correct.It`s a pre-engage starter and there is no spiral or helix.
    He needs to disconnect the power lead from the solenoid to the starter motor and power the solenoid with the starter out the engine.He can then measure what travel he actually has,not what he thinks.
    My money is on the sprag.
  5. #25
    Oct 2004
    Quote Originally Posted by A.K. Boomer
    lower one in the picture is a car boot sale find ..that ive never used.
    all the best.markj
  6. #26
    Oct 2004
    Quote Originally Posted by Mark McGrath
    it does have a helix under the pinion .
    no sprag clutch
    all the best.markj
  7. #27
    all the best.markj
    Aboard --- so it that the original up above?
    they are way way different, you cannot JAM that lower one in and expect it to work good ---- it's way longer pinon depth !
    unless there's been a mix up from the start... (no pun intended)
  8. #28
    Oct 2004
    the lower ones pinion ...is longer ..yes
    but in such a way ..in that the extra length will be just be un-used..
    the length of travel is the same.
    but the starter field coil housing is longer ........i think this is a more powerful starter for the diesel version ..diesel version has same gearbox .
    both are magneti marelli make
    all the best.markj
  9. #29
    Oct 2010
    Aboard Epsilon yes quite right mine being back feed
  10. #30
    Mar 2009
    North West Canada
    I would be very surprised if there was no sprag clutch.
    You can verify this if you still have the starter apart grab the pinion with a pair of pliers and hold the armature.
    You should be able to rotate the pinion in one direction. It will probably take a bit of force.
    Terry
