Online machining service
Is there an online machining service, where you simply send in your drawing (nothing complicated) and the part is made and sent to you. Long before I started machining as a hobby I use to make robotic/electronic projects and I would have loved such a service provided it wasn't expensive. Unless you have a lathe or a milling machine, even the simplest parts can't be made.
Albert
Albert Perhaps I cwould help you. I am a retired Machinist with a nice shop. Bridgeport and Toolroom Lathe. Give a call if you need something made reasonable. Plus im Canadian the dollar is too your advantage. What a sweet deal. Audrey and Mike
- You may not post replies
- You may not edit your posts
Forum Rules
