Results 1 to 10 of 23
Thread: Another clumsy bar steward.
    Nottingham, England
    Default Another clumsy bar steward.
    Local firm to me make big electrical cables, under sea stuff.
    Everything in this place is big.
    So they have this machine that melts and extrudes plastic to cover the cables, once started it's a process that can't be stopped.
    So yesterday morning they had problems with the machine, not sure what, but two fitters went up on the gantry and managed to get it going again but as they were tidying up one of them kicked a spare part off the gantry into the drive of the machine.
    Clumsy bastard.
    Result was the drive locked up and it sheared the key on the 60 HP DC drive motor.
    They pulled the motor and this dropped out.
    Not only did it wipe the key off level with the shaft it ripped the end completely off. Panic................
    This pic was taken as soon as the armature hit the deck, timed at 12.00 on the camera.
    One hour later at 12:56 it's been bored 5" deep and a stub shaft pressed in and the undercut transition between the two welded up.
    Grab a swift bite whilst the weld dries and back into the lathe.
    Last pic timed at 14:24 and just needs the keyway belting in but the guys have already been rung and on on their way.
    Another £7 18s and 6d to rush to the bank with.
    Sep 2011
    Belgium
    Default Pounds?
    I should hope you charged them in Guineas for that one. Pounds are so common, don't ye'know?
    What a story -- what a save!
    SJS you are the field man ------- you "git er done" dude...
    Apr 2012
    Clarington Ohio
    Good save!
    NL
    John
    Did you " knurl and a smack with brass" before the weld?!
    eddie
    please visit my webpage:
    http://motorworks88.webs.com/
    Stevens Point, WI
    Nice job!
    Curious, do you guys use mostly MIG welders to build up, fill in, and weld together stuff like this?
    Jan 2009
    Salmon Arm, BC, Canada
    Default Another question
    Hey John;
    Another question, what are you using to keep heat from migrating up the shaft and possibly damaging the armature ?
    Thanks
    Feb 2002
    central USA
    I am not too good at currency conversion--is that less than $20?
    YOU WORK TOO CHEAP!
    Nice work though!
    Say it ain't so --------- that would be insane cheap --- it should be 5 to 10 times that...
    Western New York U.$.A
    Quote Originally Posted by A.K. Boomer
    Not for Slur John. That's the price of a couple of pints and a stew plate. Life is good
    I have this burning image of Andy Capp that I can't get out of my mind!
