Results 1 to 10 of 12
Thread: Gatlin gun
    Mar 2002
    Post Gatlin gun
    Anybody know where to find plans for Gatlin gun? 22LR preferrable.
    Mar 2002
    Thers usually an ad in the back of most gun mags and HSM. I just looked in HSM and found the ad for RG-R Inc PObox 935, Trinidad Co 81082,Also they have a web site www.gatlingguns.net.I got to see four gattling guns at Cabin Fever Expo 3 in 22lr and one in 22short.I got some video of the bolts moveing into battery as the handle was cranked.If the feds would let you put an electric motor on it you could have a blast!
    If it goes BANG, I want one!
    Mar 2002
    Thanks Cannon. Wonder how long it would take to make the gun out of their materials package. the kit is way too expensive for me.
    Mar 2002
    The guy I talked to at CFX said it took apx 1 yr,did the whole thing on a smithy LMD not sure how many hrs each wk.Made his own bbls by useing liners and epoxed into steel blanks.A work of art to be sure.
    May 2001
    Have plans from both gun sellers, RG-G and MED. Am currntly building the MED version (the .22 short gun). Will do the other one later (much later). Turned my barrels down from pre-bored/-rifled blanks. If you have further questions email me direct: bdarin@localnet.com. Be glad to help you any way I can.
    Bob
    May 2001
    Utah
    I've got about 120 hours of work in my RGG gun. Figure I'm close to half done on the metal working. I'm turning down used barrels for mine and that is a slow process. I have to take light cuts due to flex of the material (I don't have a follower rest). Also, chatters alot near the middle of the barrel. Been a good learning project for me.
    Jim
    Sep 2001
    Smile
    Would'nt it be great if some dedicated person did an article on building a gatlin gun for HSM?? Hint! Hint!Hint!
    hms50
    hms
    May 2001
    Utah
    Jim
    Southern Oregon
    Hi JimH
    On turnning the long barrel with light cuts. Could you set a steady rest near the center and turn one end to size flip the barrel end do and turn that end and than work down the area where the steady rest was riding? Long question. Charlie.
    May 2001
    Utah
    Haven't tried a steady rest as you suggest. I'll take a look this weekend. I'm considering making a simple follower rest, but haven't got too far on that yet.
    One problem is that I didn't cut the original barrel (16-18 inches long) down to a little over the actual needed length (12 inches). That should help some.
    Jim
