Results 1 to 10 of 13
Thread: Quick Change Tool Post for Atlas 12x36 Lathe
    Default Quick Change Tool Post for Atlas 12x36 Lathe
    What quick change tool post is suitable for an Atlas? the slot in the compound slide is kind of small.
    May 2007
    Live Oak, TEXAS
    I'm not familiar with Atlas lathes, but if the swing is 12", then I'm pretty sure you'd want to get the BXA (and/or 200 series) QCTP.
    The 'Tee Nut' that goes into the compound slot will need to be machined to fit, but that's normal.
    I had to make a special nut to fit my old Jet lathe.
    Sep 2001
    Mountain Brook, AL
    AXA/100 or BXA/200 sizes work equally well. If you turn a lot of larger diameters along the length BXA is a bit larger with slightly greater possibility of the holder getting in the way.
    BXA will take a 5/8" square tool, where AXA only 1/2"
    Steve
    Jan 2009
    Friendswood, Texas
    +1 on the BXA (200) plus I'd go with the wedge type rather than the piston
    Randy
    Stevens Point, WI
    I built mine from scratch, i cut the slots to take 1/2" tooling like the AXA. Atlas 10x48" your 12" should be nearly identical besides a taller compound.
    Couple pics for visual. I believe my tool post is about the size of a AXA.
    Albuquerque, New Mexico USA
    The factor to consider in choosing AXA or BXA is the spindle axis height above the compound. On that basis Aloris suggests the AXA. I agreed after I put an AXA on my 12" Atlas.
    Buffalo NY
    It's only a crapy Atlas lathe. No, really, it is. Get the AXA.
    --Doozer
    Oct 2009
    Louisville, KY
    I have an AXA on my Craftsman 12"
    I have an AXA on my 12" craftsman and it is right at home.
    Craftsman 101.07403
    Grizzly G0704
    4x6 Bandsaw
    Jul 2005
    N W La.
    Consider the AXA wedge from "tools4cheap" - I recently got my 2nd set from him and they are especially nice!
