Results 1 to 10 of 25
Thread: OT: Sharpening Scissors
    Default OT: Sharpening Scissors
    My wife is a quilter. She handed me a box of scissors and asked if I could sharpen them. Well, it's metalworking, sorta, so I agreed to undertake the job, particularly as the alternative is to (gasp!) pay to have someone else do it. So off to the computer and Google, and eventually wind up at Wolff "Twice-As-Sharp" system. I have an 8" slow speed grinder that I like for sharpening wood turning tools, and I thought that the combinatation of the grinder plus the arms and clamp from Wolff would be a good solution. Yeah, I know I could make them, but that is a project too far. Before laying down the credit card I thought I would solicit the experience of the forum. What say you guys? Oh yeah, the budget for this is in the range of $250 US so anything more expensive would have to be converted into a DIY project. I don't really need another one of those, but ......
    http://twiceassharp.com/
    Thanks
    Carl
    Nov 2003
    Virginia
    I always sharpened them by hand on a knife sharpening stone. You only hone the one edge, keep at it until the edge "disappears". It needs to be a smooth edge. What I've done probably isn't as good as a factory edge, or maybe what that grinder can do, but so far they've done OK.
    Sep 2011
    Belgium
    These videos about how fine scissors are made might give you some inspiration, especially the hand finishing steps.
    http://youtu.be/LHucRh0NTPo
    http://www.youtube.com/watch?v=Kjb-NMkMNhg
    Vancouver's Island
    Just don't run while your doing it.
    Jul 2007
    My wife also is an experienced sewer. In addition, she owned, (briefly,) a wool and yarn shop, specializing in embroidery yarns and supplies. As part of her services, she had me sharpen scissors.
    All I did was darken the bevel angle of each blade with a black or blue Sharpie, and then hone the ink away with a hand-held stone or diamond padle. Most scissors only took a few strokes, and the diamond was definitely quicker. A few minutes would serve for most pairs, but if I ran into pin-nicks, they took more time. Was I successful? Everyone who used the service was happy. I cant remember what my wife charged as it was thirty years ago.
    If all you are doing is sharpening scissors for your wife and maybe her friends, then I cannot see how you can justify a sharpening rig.
    BUT, if you want a sharpening rig, and the scissors are an EXCUSE, then THAT is an entirely different matter.
    Duffy, Gatineau, Quebec
    Utah
    Here's one at Sam's Club... $80.22.
    http://www.samsclub.com/sams/chef-s-...ci_sku=101509S
    You can buy it and try it. If it works for you then keep it... if not, they'll take it back.
    It's also available at stores other than Sam's Club.
    If you want more info, it's a ScissorPro Model 500
    http://www.chefschoice.com/page2a.html
    Apr 2005
    Draw file with appropriate needle file.
    This method was used to save the life of six year old son, who used mother's sewing scissors instead of sheet metal shears!
    Texas
    I have a much simpler method of sharpening scissors. I hold a 1/16" drill bit (even a broken one will work) by the flutes in my left hand and just try to cut the round shank with the scissors. Use heavy pressure. The drill bit should be angled at the same angle as the original sharpened edges of the scissors. The scissors just slide along the drill bit and that hones the edges. A half dozen such strokes is usually enough. I then dry cut with them an additional half dozen times to remove any burr.
    Quick and simple and it produces a very good edge. This method has the additional advantage of not removing any metal from the scissors so they last a lot longer. In some cases a very light dressing with a fine stone can improve the edge after this procedure. VERY LIGHT.
    This method will not work if there is moderate or severe damage to the cutting edges. In this case, the more drastic methods above should be used. Personally, I would use my slow speed, wet wheel for that.
    Jul 2002
    My grandmother would do that and then take several cuts on a piece of very fine sand paper until she was satisfied her scissors were sharp.
    Apr 2012
    Western central Fl
    Quote Originally Posted by Rustybolt View Post
    My grandmother used to do the same thing with a coke bottle, using the section where the cap crimped on.
    Ken
