Now that I have finished the Atkinson engine, its time to start thinking about another machining project. I don't think I want to build another engine of any type, as I am somewhat over-ran with engines now. I have 10 different steam engines and 3 internal combustion engines. The steam engines, which I run off my air compressor are fun to look at, but rather gutless in terms of power when compared to the i.c. engines. My favourite i.c. engine is the Kerzel hit and miss that I built a couple of years ago. Even it would probably not have sufficient power to run a circular saw blade, but I am thinking in terms of the old mills which were water powered and had a vertical blade that moved up and down like a jig-saw. These sawmills didn't require a lot of power to drive them. The log wasn't fed into the saw by a cable driven carriage, but there was a ratchet and paul device that would move the log into the sawblade during the downstroke (which was the cutting stroke) and "pause" the log during the sawblades upstroke so as not to put pressure on the blade when it was lifting. I have to do some more research on this, but it might make an interesting project. A fine toothed sabre saw blade would probably be close to the right size, and the "logs" to be sawed would be peices of 1" diameter wooden dowel.----Brian
