Results 1 to 10 of 17
Thread: Sticking 3-wires for thread measuring??
    May 2007
    Live Oak, TEXAS
    Default Sticking 3-wires for thread measuring??
    What's a simple trick to stick the 3 wires to the part, when measuring with a mic?
    Seeing as I don't have 4 arms.
    Woodinville, WA
    GREASE, grease, grease
    Sep 2012
    Poplar Bluff, MO
    I set the mic a tad bigger than I expect and use my fingers to hold the wires as I slide the mic over them.
    John
    Jun 2006
    Austin, Texas
    Black (or pink) electrostatic foam works great, and no mess cleaning up the wires.
    Apr 2011
    SW Michigan
    Hate to sound(& be) stupid, but can someone explain how this works? Thanks!
    The richest man hasn't the most but needs the least.
    Keep Calm and carry Guns! Old Friend of Old Iron.
    Always Plan for the Future but Live for the Moment!
    Mar 2010
    I use a lump of modeling clay. Pressure from the mic will move the wires into the proper position and give an accurate reading.
    RWO
    Owensboro KY
    Quote Originally Posted by flylo View Post
    the grease or the three wire method?
    Here's a site that explains the three wire method: http://www.threadcheck.com/the-three...technicalinfo/
    I remember some thread wires that were called "Flin Wires" (sp?). They were not accurate enough for Mil-Spec parts, but close enough for virtually everything else. Seem to remember a set had fewer wires than usual and it included a chart that made it easy to calculate the PD.
    The grease acts as stickum to hold the wires in place. Just hit the part with some electromotive or brake clean to remove the grease.
    Grease to hold the wires on the work....or stick the wires in plasticine (modelling clay) are both things I've used. They reduce the frustration from a 12/10 to about an 8. The wire falls off the grease, the move and shift in the modelling clay..Arrg
    we should use thread wires all the time.....its only because they're a 8/10 on the miser scale that we don't
    I've got a way to reduce it to a 3. snip two pieces of bicycle inner tube maybe 3/8 wide and an inch long. Punch a 1/4 hole in the centre (mics in my experience are 1/4" anvils). with an exacto knife make two slides at each end.
    Slip the wires through the slits, two in one and one in the other and then the whole assemblies on the anvils. It works well. There is a commerical product out plastic that does the same but the price is just plan stupid
    Aug 2003
    Empty the chip pan BEFORE using the wires !!
    Dec 2010
    Finland
    Quote Originally Posted by lazlo View Post
    Probably the best (cheap) solution I've seen yet Have to try this next time when I'm making a thread that I have no gauge for.
