Results 1 to 10 of 17
Thread: New improved FSWiszard?
    Germany
    Default New improved FSWiszard?
    There is a new version of FSWiszard out called HSMadvisor. http://hsmadvisor.com/index.php?page=Download
    Have any of you all tried it yet? It now includes turning. I have tried it for a few days and it seems to do what I need.
    I would be interested to read your thoughts. Being as I am not very experienced in machining I need all the help I can get at least with a jump off point regards feeds and speeds!
    Oct 2012
    Ontario
    I am glad it is working out for you.
    I did a quiet release a couple of days ago.
    There are many new things in there. Turning, thread milling, built-in tool database and such.
    I am more interested in things that it does not do.
    For this reason like i said before every update will bump up trial counter to 30 days.
    This way, i hope, users will feel compelled to suggest improvements and in return get to use my program for free. How is that for a deal?
    The next things in the pipeline are threading and tapping.
    Also if anyone is experiencing difficulties, i would love to help out.
    Oct 2012
    Ontario
    I have just released a new build.
    With several new features and it has all of the bugs i could see fixed.
    Also new materials added to the Online version
    You can download newest HSMAdvisor here
    Nottingham, England
    Been quietly using this for a few weeks and find that the figures given are very good to actual cutting data.
    One thing where this excels is that most commercial programs spit figures out that bear no relation to the machine it's on.
    OK for industry who has 3,678 HP on tap [ approx ] but if you only have an X2 mill with 500W on tap then it's a different ball game.
    Also like the fact that it also recognises that the rest of the world uses metric units.
    Keep up the good work.
    Carbonear, NL Canada
    Yes
    I just did a down load and had a go.....nice
    Looks like it will work well with my BP CnC
    I can enter Max H.P. along with max speed and feed for my machine and get real numbers.
    Nice work .
    eddie
    please visit my webpage:
    http://motorworks88.webs.com/
    Germany
    You added some European steels to the materials list. Danke! I use C35 and C45 quite often.
    Mar 2010
    switzerland
    are you supposed to go 67 m/min with a tiain coated hss mill?
    Jan 2007
    Fletcher, NC
    I got a "This unsafe software was blocked by Smartscreen Filter" message when I tried running the *.exe install file on Windows 7/64.
    Previous version of FSWizard ran but required a Ctrl-Alt-Del to Task Manager to close it down on this machine.
    David Merrill
    Germany
    Quote Originally Posted by demerrill View Post
    David Merrill
    I am running it on a Win 7 64bit system also. I couldn't get it to run on my XP laptop. I was having issues with the .net framework. I gave up an put it on my Win 7 laptop.
    Oct 2012
    Ontario
    Quote Originally Posted by dian View Post
    Depends on what material.
    What engagement and so on.
    You did not give enough info for me to help you out.
    FSWizard - Free Online Speed and Feed Calculator
