Results 1 to 9 of 9
Thread: looking for an ISO G 1/8 tap
    Jul 2007
    Central Connecticut
    Default looking for an ISO G 1/8 tap
    Hello,
    I hope everyone is doing well. Things were going well for
    me with a high-pressure bleeder plug I'm putting into a SS housing for a potted tach-connector
    assembly used on a hydraulic drive used at a sea depth of up to 1500 meters.
    I need an ISO G1/8 (28 threads per inch) tap. The one Parker offers costs $131.00 each, and has a lead time of 4 weeks, so they are obviously not the place to deal with.
    I was hoping to get 3 of them, but the price is too high. Does anyone know of a good source
    for these? I could really use any help I can get on this.
    Thanks,
    Ray
    aren't these the same as British Standard Pipe Threads? msc# MSC #: 88244959
    http://www1.mscdirect.com/cgi/NNSRIT...-SearchResults
    Jul 2007
    Central Connecticut
    Yes, I believe it is a British Standard Pipe Thread. I was looking for the ISO and/or DIN designation,so I didn't catch it on my initial MSC search, but the MSC #: 88244959 looks like the right one. Thanks so much for your help. My day is looking brighter now.
    Sep 2008
    UK
    Need to be careful - 'G' threads are parallel, i.e. BSP, not BSPT (taper) as per link.
    Cheers
    Quote Originally Posted by Barrington View Post
    Cheers
    good catch....would this be the one? Almost wrecked your day hoof
    Sep 2010
    Wheaton, Illinois
    ISO 228 - replaces DIN 259 (Withworth pipe thread, parallel internal and parallel external.
    These threads do not seal in the threaded portion but seal by tightening two shoulders with a seal ring between them if needed. Used on fittings, valves etc. if a high degree of sealing is required.
    G1/8 - 28
    Outside dia....9.728
    Pitch dia........9.147
    Core dia...8.566
    NL
    Hi
    G1/8 BSP 1/8-28
    KBC Tools carries these as well as etap.com
    If you are not in too big a hurry you can usually find them on e-bay
    links:
    http://www.e-taps.com
    http://www.kbctools.com
    please visit my webpage:
    http://motorworks88.webs.com/
    Jun 2006
    Austin, Texas
    Quote Originally Posted by Juergenwt View Post
    Whoever came up with ISO-G should be strung up by the balls -- I posted about those mongrels when I rebuilt my Eisle cold saw: Whitworth threads with Metric orifices
    European G 1/8 pipe threads?
    http://bbs.homeshopmachinist.net/thr...-threads/page2
    The ISO-R have the BSPT (tapered threads).
    Dec 2006
    Hazel Park, Michigan
    I hate those straight 4 flute taps, they cut like ...crap...this is a little pricy but it has lasted me a long while...little effort to cut the thread, nice clean results...
    http://www.amazon.com/dp/B003JY6N64/ref=biss_dp_t_asn
