Page 1 of 18 12311 ... LastLast
Results 1 to 10 of 176
Thread: DIY slip roller, tubes or solid?
    Stevens Point, WI
    Default DIY slip roller, tubes or solid?
    Looking to possibly build a slip roller. Some of you may have seen the fire ring I made, I made the ring with my brake and bending a slight amount every 1.5-2". I would like to make a slip roller for future fire rings and whatnot. Questions I have are use a tube or solid for the rollers? Anyone have some plans for one or have built their own? I am looking to be able to roll 1/4"x10" possibly 12". I assume if tubes are fine, the wall thickness should be thicker than the material being rolled? Thanks much for any help!
    Mar 2009
    Ohio
    Hi,
    For what its worth my 22 Ga. x 24 " Pexto rollers are solid. Guessing about 2" in diameter. ( not close by or I would measure for you )
    Toolznthings
    Jun 2011
    Northeast, PA
    I am also going to say solid, but I am not sure. I would think you may need around a 3-4" rollers to roll 1/4" in a 12" section. I would also think about powering it, that is some heavy cranking to roll that thick unless you have it geared down, then it is just a lot of cranking.
    Apr 2007
    South Texas
    If you are going to make the rolls larger in diameter you could probabaly use tubing. The problem will be that you still need to have some type of bearing and it would probably be easier to make a sold roll of smaller diameter. A larger diameter roll would mean lower forces. a smaller diameter roll would mean the curve would go closer to the end of the strip. rolling after the welding would make it more round.
    Feb 2005
    gettysburg pa.
    the gearing idea is right. i would look at a roller for making the tires for the old wooden wagon wheels.
    Deep in the Heart of Texas!
    I too would go with solid rollers. It's often cheaper than cored or thick wall tubing of the same material. You'll want something that's harder than the stock you're rolling or the rollers will scar. The force necessary to bend 1/4x12" mild steel will vary greatly depending on the distance between the outside rollers. The inner roller would need to be able to apply this force and outer rollers would need to support it without much deflection. The force may be any where from several hundred pounds at 12" to several tons at 6" between rollers.
    Nov 2010
    Portland Oregon
    I know a guy that took a HF tubing roller and remanufactured it to a slip roller using the wheel and some home made parts for his. It did have solid rollers as we had a (shared 10') stick of 3" CR steel that we both have used some of. I will see him next month maybe I can get a picture but not any sooner then end of July. We have used it for sheet metal up to 16ga works real well, 1/4" probably would go OK but might be a real workout to crank.
    Mr fixit for the family
    Chris
    Mar 2011
    Iowa
    I'm trying to design a roller as well. Only I want to do 1/4"x36" if I can get away with it. I picked up some 4 1/4" solid round at auction last weekend I'm hoping will work. Anyways.....my press brake chart says that 1/4"x12" will take 4.5 tons with a 5" V die. So I'm guessing centers on the rollers need to be a little over 5" to require the same force.
    The real problem is figuring how much roller deflection is acceptable and how big of a roller it will take to minimize that deflection.
    Solid doesn't add a lot to the bending strength after a certain thickness, but it does improve the crushing strength, which you need for rollers...
    Solid.
    Jun 2011
    Northeast, PA
    ^^^^ I think that 4.5" may be border line for 1/4" at 36 wide. This one uses 6" for 1/4" at 48 wide. http://metal.baileighindustrial.com/plate-roll-pr-403
