Results 1 to 10 of 24
Thread: Want to make a bench grinder arbor
    Dec 2011
    Denver
    Default Want to make a bench grinder arbor
    I've been looking into bench grinders and found a few options:
    http://www.grizzly.com/products/8-1-...-Grinder/G0596
    http://www.grizzly.com/products/10-1...-Grinder/G0597
    http://www.grizzly.com/products/12-3...-Grinder/G0599
    Then I got to thinking since I have a 3hp 3phase motor with vfd, why not make a heavy duty double ended arbor? I can't find threaded rod to use that has both LH and RH threaded ends. I found this but it doesn't say the threads are opposite.
    http://www.mcmaster.com/#threaded-pr...shafts/=od8zb6
    Are there premade rods that can be used for this application? The pillow blocks and guards can be sourced but the rod would be great to find ready made.
    Thanks in advance for the help.
    The McMaster threaded rod will be all right hand threads.
    Jan 2013
    SW. Michigan
    I was at the scrap yard a few month ago as i looked around for usable steel i saw this old 8" bench grinder with babbitt bearings it had all the guards and grinding rests. I figured i might as well take it so this winter when i get the blahs i will rework it hopefully can use pillow block bearing on it. The price was right
    Oct 2012
    Eureka, California
    PT Doc,
    In my opinion, the most important part of the bench grinder would be the arbor, its run-out and accuracy. This...IMHO would require you to make it from TG&P shaft with left hand and right hand threads turned on the appropriate ends. Good, accurate collars and bearing fits would be paramount as well. These are the things that make a smooth running grinder, no matter how large. I built a 10" grinder from scratch, paying attention to these details and it worked out very well.
    Make sure you don't over-speed the wheels with your frequency drive!
    Stuart
    Dec 2011
    Denver
    Quote Originally Posted by atomarc View Post
    PT Doc,
    Stuart
    By picking the right pulley size I would be ble to not over drive the wheels that I choose.
    Oct 2012
    Eureka, California
    Doc...sort of true, but remember, if one wanted to, the drive (VFD) could be programmed for a max output of probably 400 Hertz. The stock motor will run at nameplate RPM at 60 Hertz so it's not out of the question, pulley size or whatever, to scatter those big wheels all over the shop. Not likely with half a brain but it could be done.
    Stuart
    Cheyenne Wyo
    I made my buffer with collet ends and nuts, then the arbor stays with the wheel. Think of the business end of a Dremel tool. Not commercially available... but once you true the wheel on it's arbor it stays that way.
    I'm here hoping to advancify my smartitude.
    Dec 2008
    N.E. oHIo
    Quote Originally Posted by PT Doc View Post
    You need a copy of this book: http://www.amazon.com/Spindles-Works...e+series+books
    Rex
    Mar 2010
    FWIW, Grainger sells motor shaft arbors for grinding wheels with RH and LH threads and for 1/2" and 5/8" motor shafts.
    http://www.grainger.com/Grainger/sha...rue&Pid=search
    RWO
    Bremerton Washington
    You got a lathe? Can you borrow one?
    Bench grinder arbors are much better if purpose machined. Nuts, washers. and pipe spacer on threaded rod does not cut it. Besides being lame looking and ugly (not a problem with me) they will not perform well (a big problem with me). A threaded rod arbor will be crooked, run out of balance, and a re-mounted wheel will require heavy dressing to true it up.
    Square shoulders, machined flanges, accurate bearing fits, true running RH and LH threads, and a smooth diameter to center the wheel on are all vital attributes for a good grinding arbor. The bearings can be pillow blocks (bronze or ball) or in a machined housing. It could be a monument to home shop fabrication or a simple belt driven arbor in bearings in the same fashion uor grandpas made theirs.
    I bet I made a million bench grinder arbors over the years - well 50? 30? something like that. I made one for my dad in sealed housings. It was a monster made to his design to fit a 16" wheel he scrounged. We got it all set up but before we mounted the wheel, I "rung" it - tapped it with a screwdriver handle. Clunk! Not "ding" but "clunk." It was cracked. Rats. We had an arbor but no wheel. Too bad. A wheel that size would go for $200. I still got the arbor and bearings.
    Anyway, you can buy heavy pattern RH and LH nuts but the arbor and flanges if not store bought as arbor components have to be made.
    But it starts with a machined arbor.
