Results 1 to 10 of 19
Thread: Alloy tank fabrication - video
    Apr 2012
    warwickshire, UK
    Default Alloy tank fabrication - video
    if you're into alloy fabrication, this video of making a bike fuel tank will be of inspiration, includes gas welding aluminium
    boy is this ever a timely post...
    are you sure your not just whoopin up on Andy's late great tank freeze fiasco?
    the statute of limitations are up on that one and it is safe to laugh about it now,,, I think?
    Nov 2010
    Farmington Hills
    I have gas welded aluminum before and he makes it look easy. The problem is that unlike steel, aluminum shows no indication of how hot it is. It also takes very good torch control to be able to get an area hot enough to weld but cool enough that it doesn't collapse. I love my TIG welder.
    Thanks for posting the video.
    Tom
    Jul 2001
    Green Bay, WI
    Well, when I looked at this post, I said "no way am I going to watch a 42 minute video.
    Man, was I wrong
    This guy is highly skilled and he proves it by using the simplest tools.
    I couldn't shut it off. I did miss most of his comment due to a hearing problem I have and his slight accent
    Thanks for a trip seeing a real craftsman
    Rich
    PS
    Pay particular attention to the 26 to 28 minute part where he explains the heating of the seam and why the joint is made so.
    Last edited by Rich Carlstedt; 09-24-2013 at 07:09 PM. Reason: forgot the time remark
    Stevens Point, WI
    We were all laughing in the moment. lol
    I would like to know how to build a torpedo type tank though like the water witches. Now that I can see inside the tank I may only see one weld on the one end like a cap.
    Mar 2010
    Winnipeg Manitoba
    suppose you could just beat the panels but guessing metal spinning (granted relative to something like an airplane wing tank, quite small...still...)
    Buffalo NY
    Gas welded aluminum like a pro.
    I would have a blob on the floor
    and lots and lots of cuss words
    I am sure. Hell, sometimes the
    cuss words fly when I am TIG
    welding. Tung in the puddle
    again. Augh!
    --Doozer
    Apr 2003
    New Hampshire
    Outstanding work!!!!
    Farmington Hills, MI
    Thanks for posting the video, amazing good work ! Gas welding of aluminum was the common method back before TIG. Think of all the WWII aircraft components and various fluid tanks, all aluminum, that were gas welded.... many I suspect by newly trained "Rosy the Riveter" gals.
    Joe B
    and I didn't even know you could do it, thought it was to dirty...
