Results 1 to 4 of 4
Thread: Programable indexer
    Nottingham, England
    Post Programable indexer
    Ok guys.
    I posted a bit about this in a thread called "Off the secret list" a while ago.
    Got to play with this a bit more serious today.
    Set the big Hoffman dividing head up on the horizontal mill with a mandrel to hold some change gears. These are 27 teeth 14 DP but the old 14.5 degree pressure angle that are nearly impossible to find.
    These are actually metric conversion wheels for a Clausing Colchester for a guy in the States.
    Shot of the job is at:-
    http://homepage.ntlworld.com/machines/divmaster5.jpg
    Pics from top left working clockwise are:-
    [1] General shot of the layout.
    [2] Close up after cutting seven teeth and nearly finishing the 8th.
    [3] Shot of the Division master display at this point. Shows the number of divisions programed. Number of completed passes and the current position of 93.330 degrees. The true position should be 93.333 degrees.
    At any given point the biggest error was 0.008 degrees.
    [4] Shot of the finished four gears.
    This is one neat bit of kit. For a better look at what it can do visit their web site.
    http://www.divisionmaster.com
    John S.
    Mar 2002
    webster, ma
    john, msc stocks 14.5* and 20* cutters. as far as i know both should be common cutters, but finding a 14 pitch gear in a catalog, ie off the shelf, is not possible oe either angle
    gvasale
    Nottingham, England
    Actually HPC here in the UK do carry 14 DP gears as a stock item but all their range is in the more modern 20 degree form.
    John S.
    Question
    John
    Nice. When are they available? How much?
