Results 1 to 10 of 36
Thread: Ram pumps anyone?
    Dec 2010
    Finland
    Default Ram pumps anyone?
    Is there people on this board that have made a hydraulic ram pump for themselves or for a friend? I've been wanting to build one for ages and finally it is on my next-projects-list I do not have a creek or a river or similar, this is just for fun and learning, because the time I find a place that has a natural water source, I'll bolt this kind of thing there to supply me with water 24/7.
    I just love watching and listening to the slow kachunk --- kachunk --- kachunk sound and seeing a pump operate without electricity or fuel and the fact that it has two moving parts.
    I recently went to this website and that was my deal breaker there, the waste valve design that the AIDFI ram pumps also use. I'm planning on making something like the AIDFI demo ram pump, so the body will be something like 60 mm wide or so.
    I think I'll go and find me a stainless steel door hinge with a suitable size or if I can't find one, then its back to the machine shop to make some other hinge idea.
    Materials I'll be needing are probably some heavy wall 60 x 60 tubing, some angle iron for the feet, stainless steel plate or cut-off from a bar for the valves, piece of inner tire or a rubber sheet, some round pipe, some round pipe or the like to make the flanges and then a handful of nuts and bolts to fudge it together But first, let me take a self..err...make a CAD drawing to figure out the needed sizes.
    Apr 2004
    CenCoastCal
    Default Ram pumps, eyeball candy-
    Watched last weekend, at Vista antique engine and farm equipment show, this ka-chunk, ka-chunk, ka-chunk hydraulic ram pump at work. Never was able to convince wife how the thing works, or why.
    A first for me, but always fascinated by the simplicity.
    --G
    Dec 2010
    Finland
    Just earlier today I got off the phone with The Finnish Safety and Chemical Agency that monitors things like product safety, work safety and such and one thing they also monitor is pressurised containers and systems. I was asking what regulations there are and what tests do I have to do in order to be able to manufacture such a pump and/or sell one to another individual. Usually products in the EU have to be CE marked, but in this particular case I'm not allowed to do so, as the pressure container is "too small" for anyone to care about it, as long as "good machine shop practice" is followed and end user is provided with complete instructions for use & maintenance But I still have to check if I have to stamp the CE on the pump body itself, as it is technically a machine and there are some directives that specify what sort of safety systems a machine has to have or needs. All in all, it is good that there are specialists that you can call for free to ask advice and can rely on that information to be correct in the eyes of the law.
    Haven't yet started drawing the model for this, but I found some nice 60 x 60 mm thin wall (2 mm) tubing that I will probably use for this small model. Also I think there is some suitable size pipe in the storage rack at work to make the air chamber. I'm not sure if I have any suitable sized plate of stainless for the valves, so I might have to make a scrap yard run for that. Gasket material I have, door hinge I didn't go looking for yet as the hardware store is already closed, but nuts & bolts I do have as well as material for the flanges.
    The test setting will be 1 meter fall from a bucket or something and I'll attach a pressure gauge to the air chamber to see how much pressure I will get to determine the maximum lift height. Drive pipe will be probably around 30-40 mm in diameter, have to check what I have.
    So in short this is starting to look like a project that might actually succeed
    Bremerton Washington
    Suckers really work.
    My dad and I bought an old farm that had a ram pump in the creek. It was plugged with sand but we cleaned it up and doctored the valves. We ran a steel ram pipe (important; the pipe wall has to be rigid) It kept a stock tank full of water at our picnic site for 20 years. We had maybe 3 ft of fall in 200 feet or so and it pumped maybe 40 ft uphill to the stock tank. I'm guessing a gallon a minute delivery. Clink - clink - clink; all day and all night. Absolutely unattended. No power, no bucket brigade, no nothing but clever ancient art.
    Look here:
    http://www.nrcs.usda.gov/Internet/FS...2p2_041913.pdf.
    Our pump had a 3" inlet for the ram pipe and a 3/4" discharge. We used 1 1/2 IPS ram pipe because that's what we had. It didn't want to cycle on the 1 1/2" ram pipe but we jiggered the discharge valve so it worked. Getting the pump running was strictly a Saturday afternoon project mandated by Mom so she didn't have to go to the creek to wash dishes. 6 hours of work fetched 20 years of convenience. This is yet another example of how SWMBO's complaint galvanized mankind's advances.
    Oct 2013
    http://www.clemson.edu/irrig/equip/ram.htm is an example with everything already worked out and doesn't use any expensive or hard to find parts.
    north bay area
    Indeed those rams are fascinating old technology!
    Dec 2010
    Finland
    Quote Originally Posted by jlevie View Post
    Have run in to that several times, but the thing is that it isn't good, it requires parts that are not easily available everywhere and it is not easy to scale up, as the bigger fittings are either not available or cost more than a truck. Also it will have lots of internal drag and added turbulent flow due to multiple junctions and the waste valve isn't easily tuned.
    But for someone just needing a quick ram of that size it works
    Germany
    I have for several years contemplated building two of these pumps to supply water to two pastures I have that have creeks close by but not in the pasture. There is more than enough fall available. It will be interesting Jaakko to see what you come up with.
    It's as much the length of pipe as it is the fall. Essentially they use "water hammer" as the power source, so you need a mass of moving water.
    Don't forget the "snifter" valve to keep the air chamber full.
    1502 0522 1499 2501 2509
    Dec 2010
    Finland
    Yup, the optimum drive pipe length is 150 - 1000 times the inside diameter, so it isn't very exact but is recommended to be between those numbers for the shock wave to act correctly. The fall mainly dictates your maximum output to a certain lifting height, as in if you have Q as your drive pipe flow, e as your lifting height, f for your fall and assume 0.6 efficiency, then the output flow will be 0.6 * Q * f / e.
    Oh yeah, good point, I'll either add a very small hole or make a ball bearing snifter, though last option would be to use a bicycle tire or similar. I'm aiming for the simple hole, as it is atomatic and doesn't need any additional parts to the design
    I'll try to get some drawings here later today, have to run some errands first.
