Results 1 to 10 of 12
Thread: What tooling do these inserts fit?
    Default What tooling do these inserts fit?
    I couldn't find them online. Are they older naming? They must fit something.
    Thanks,
    Rich
    Woodinville, WA
    A lot of the older inserts like that were for silver soldering onto steel shanks.
    Germany
    I have a very old Walter face mill that uses inserts of that type. No hole and square. They get clamped in place.
    Sep 2009
    Spencer MA USA
    The flat top, no-hole milling inserts will have an ISO or ANSI standard designation such as SPKN1204 or SEEN43. That box is probably as lakeside53 says, a simple blank used for silver soldering onto a steel shank. I might suggest it could be a wear pad for some mechanism, but the grade CY-7 gives it away as a grade for machining steels. The "style M-168" makes it non-standard and if an indexable insert, would go into a very proprietary holder.
    Aug 2013
    Van Alstyne, TX
    I got 4 similar boxes in a lot at an estate sale about a year ago and have not been able to find out what they fit. I believe that mine have a larger radius on the corners but other than that look the same. I have just resigned myself to making a tool holder for them if I ever use them.
    Hi, my name is Wilson and I am a tooloholic.
    Sep 2009
    Spencer MA USA
    They are worth more as scrap carbide than they ever would be worth spending time to make a holder and get questionable performance out of them.
    Jan 2014
    New Mexico
    Quote Originally Posted by RichTes View Post
    Thanks,
    Rich
    they look like SPG434 inserts. I use them in a Shars facing mill:
    http://www.ebay.com/itm/new-VALENITE...item3a8d03430c
    http://www.ebay.com/itm/SHARS-2-75-R...item519ffb9098
    Mar 2012
    in dixie
    Save them for when the price of scrap carbide rises again.
    Sep 2009
    Spencer MA USA
    Quote Originally Posted by ken226 View Post
    If they were SPG434 inserts don't you think they would have been marked as such?
    There is no sense of scale in the photo. We don't know if there's a side clearance angle, and if there is, what that angle is. (An SPG would have 11)
    I don't understand why people obsess about saving $2 worth of scrap carbide for use in something when you don't need it. Having a little carbide to dispose of is just a matter of collecting it until you have a couple of pounds (or a couple dozen pounds) to unload and turning it in for tools you can actually use.
    Deep in the Heart of Texas!
    Quote Originally Posted by PixMan View Post
    LOL... I have a couple of 3/8" carbide rods I've been saving for years just waiting for the right time and place to use them.
