Page 1 of 2 12 LastLast
Results 1 to 10 of 33
Thread: long-term rust protection of bare metal
Hybrid View
    Oct 2005
    Lower SE Michigan, USA
    Default long-term rust protection of bare metal
    Included with my '32 Coupe are several pieces of sheetmetal, presumably repro parts. There's a RF fender, pair of running boards, a floor pan for the rumble seat area, and the shroud that goes beneath the radiator and wraps around the front inside of the springs, plus a spare tire "well" or pocket that goes in a front fender. This is all bare, unpainted steel, and I have no immediate plans to install the stuff.
    How best to protect it? I'm thinking of spraying it with a light-weight oil of some sort. (ATF?, motor oil?) Everything will be stored inside, but not in a heated area. This protection might have to last 10 or more years.
    Jan 2003
    Chilliwack, B.C.
    Maybe think about priming it. You will end up re-priming later, but for now it would be a full coating that won't evaporate or wipe off on things.
    Jun 2012
    San Diego, Ca *** Please let us know where you are from too.
    Primer doesn't stop rust. Common misconception.
    Aug 2004
    Sunny So Cal
    LPS3
    Dec 2015
    Chilliwack, BC, Canada
    LPS3.
    Or if you have trouble finding it locally then look in the motor cycle shops for some chain wax.
    Sep 2008
    WI/IL border
    LPS3
    Sep 2007
    North Carolina
    Quote Originally Posted by Mike Amick View Post
    Every once in a while I'll see a car being driven around with a coat of primer on it and feeling sad knowing the really hard lesson that the car's owner is going to get about why you don't do that.
    Steve
  8. #8
    Feb 2005
    gettysburg pa.
    to keep my saw blades from rusting I use mothers wax. works on the hand saws and the buzz saw that goes on the back of the tractor.
  9. #9
    Dec 2007
    South Wales
    Phosphoric acid rust converter?
    Mark
  10. #10
    Dec 2007
    Montvale, NJ
    If you really have no plans for these parts for 10 years, just roll on a quick, thin coat of exterior latex paint. I would feel better stripping that and painting over the panel rather than putting oil or other rust preventative on it.
