Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: OT, anyone want to settle an automotive spindle debate?
    Sep 2006
    Big Prairie Mi.
    Default OT, anyone want to settle an automotive spindle debate?
    part in question:
    http://www.dennysdriveshaft.com/p456...lor.html#photo
    The debate is (A) whether D supports the weight, or (B) the cap screws passing through f/k support the weight.
    I'm in the A camp, because 'D' is a tight fit that requires pulling it in with the screws, which are smaller in diameter than the holes in the flange. something like 8mm bolts through 10 mm holes (WAG)
    Mar 2003
    That's not even a debate. Stub "D" sockets into the spindle and bears the bulk of the weight of the truck. The bolts in effect only restrain it against lever/bending forces. That's how they were designed.
    Doc.
    Oregon
    If you pull the bolts out will the weight dislodge the spindle? If so then the bolts are supporting some of the weight. If you removed the D feature would the spindle still function just being held on by the bolts? I think the bottom line is that they both play a part in supporting the vehicle. You will find that D is in shear and the bolts in tension. Remove either and it will fail.
    lg
    no neat sig line
    Aug 2004
    Sunny So Cal
    I am in the both camp. Two types of loads (up and down and sideways), two types of support. JR
    Apr 2003
    A and c support the weight with bearings installed
    Oct 2005
    British Columbia
    Quote Originally Posted by larry_g View Post
    lg
    no neat sig line
    I'm with Larry on this one. I think if one would examine the interface between D and the steering knuckle very carefully you would find some clearance between the two, they are not a press fit.
    Without the clamping force securing the spindle to the knuckle the assembly would fail. Normally these two surfaces clamped together would carry the load.
    In a high load impact scenario the pilot (D) would ensure little to no movement between the two. Probably why both methods are used in this critical application.
    Mar 2015
    Both
    Netherlands
    Neither. The friction between the flange and what it's bolted to is taking all the load. Once the bolts are tight you can remove the boss and not notice.
    Now when the bolts are rattling loose it's nice to have the boss otherwise you might shear off the bolts. It's very convenient for locating the spindle as well while tightening the bolts.
    Yes Larry's post has nailed it, there's two types of forces going on - the supporting factors are not jack squat without each other, but both combined are rock solid...
    Nov 2010
    Northern NY
    Agreed with ikdor above. Its commonly called a clamping load here stateside.
