Page 1 of 36 12311 ... LastLast
Results 1 to 10 of 357
Thread: Oroville Dam disaster
    Feb 2006
    Phoenix
    Default Oroville Dam disaster
    This is OT., but I wonder if we have any members in the vicinity of Oroville. As I understand it the emergency spillway is expected to fail (the primary spillway is already out of action).
    Oroville, the highest dam in the USA, is apparently not in danger of failing. But if the emergency spillway is eroding I don't understand how the integrity of the dam can be maintained.
    I don't have a good link to streaming coverage, or coverage of the streaming (take your pick). I hope this will not be hard to find.
    Allan Ostling
    May 2009
    Canada
    Fail? As in erode away due to flow exceeding volume/duration design limits? Or due to something else?
    The title says 'Oroville Dam Disaster'. Has the disaster begun or is it pending. What is at stake.
    Cue up Vera Lynn and let the credits roll ...
    Sep 2013
    Quote Originally Posted by aostling View Post
    You are making **** up
    The sluice way concrete surface surface has broken up in some areas, but that is not a disaster.
    May 2009
    Canada
    Ok, found a recent video. Definately looks serious, I sure would not want to be downstream tonight after what I just saw ...
    LiveCopter3 surveys Oroville auxilliary spillway
    Oct 2005
    British Columbia
    I've been following this story since it's inception. Very tense situation, seems as though developments are changing by the hour.
    My best wishes to all of those affected by this potential catastrophe. Hope they get a handle on it soon.
    The latest news is not good!
    http://www.latimes.com/local/califor...htmlstory.html
    Feb. 12, 2017, 8:05 p.m.
    "This is not a Drill. Repeat this is not a drill,” the National Weather Service said Sunday, urging people living below Oroville Dam to evacuate. The evacuation was ordered because of a “hazardous situation” involving the Northern California dam's emergency spillway. The National Weather Service said the auxiliary spillway is expected to fail and could send an “uncontrolled release of flood waters from Lake Oroville.”
    Home,down in the valley behind the Red Angus
    Woodinville, WA
    Quote Originally Posted by CalM View Post
    He's not and that not the issue. The emergency spillway (not the concrete spillway) is being undercut so they have now massively increased the flow down the damaged concrete spillway.
    As at 8 pm pst it looks like the disaster many be avoided - lake has fallen almost enough but the main spillway will be toast.
    Aug 2014
    San Jose, CA:Vancouver, WA
    Fortunately the spillway and emergency spillway are separate from the dam and the dam is in no danger. But, many thousands of residents have already evacuated because of the risk of the emergency spillway failing and causing downstream flooding. And a major rain is forecast in the next couple of days. So, they still have to let the damaged spillway carry water to lower the lake so the coming rains won't cause the emergency spillway to fail catastrophically.
    It will be a tense few days for residents downstream from the dam.
    May 2009
    Canada
    In the video link earlier, near the end there is footage of a bridge well down river where the water level appears nearing the underside of the spans. Odd to see heavy evacuee congestion in two lanes of the bridge while the other two lanes (opposite direction) remain empty.
    Sep 2006
    Big Prairie Mi.
    Hopefully they get it under control soon, Apparently no smaller dams upstream?
    Biggest problem with the spillway is that it's an earthen dam, same as Hardy up here. It's essentially a dirt pile supporting a thin concrete face on the upstream side. A failed spillway is not good at all for an earthen dam.
    Sep 2015
    NW Illinois
    In the video I see water leaking through the embankment to the left of the emergency spillway. That is a very bad thing. If I lived below the dam I would be very frightened.
