Results 1 to 10 of 20
Thread: Press fit bearing hole
    Jul 2007
    No Cal.
    Default Press fit bearing hole
    Need to machine some parts that will hold a press fit bearing 64mm O.D. and 37mm Depth pocket in some 6061 Al. I know the .002" interference and the chill the bearing heat the part. My question is this ..
    I was planning on milling the pocket .010" under and finishing off the pocket with a boring head. Then measuring with my bore gauge to ensure there is a proper fit with no taper
    This sound reasonable to you guys
    Woodinville, WA
    Sure.
    Don't worry about chilling the bearing; Heat the AL to 300f and it will drop in.
    A boring head is the best way to get a round, true hole. Especially good for use with bearings.
    Apr 2016
    USA
    Sure.
    Yup, should be no problem in aluminum. Don't go too crazy with your press fit though. Especially in steels you can actually shrink the bearing race around the bearing balls.
    Sent from my XT1053 using Tapatalk
    Sep 2015
    NW Illinois
    .002 seems like excessive interference. SKF and other bearing manufacturers have online technical data that specifies hole tolerance for different operating conditions. Those should be your guide.
    Apr 2016
    USA
    Quote Originally Posted by Illinoyance View Post
    On a 2.5" bearing that's roughly the correct interference fit as far as I know, although I would be interested in knowing the tolerance "By the books".
    I've always heard the rule that a good interference fit is .001" per inch of part diameter. I wonder if it's true?
    Woodinville, WA
    Quote Originally Posted by Andre3127 View Post
    Yes.. and that's one reason why you use C3 ("looser then normal") fit bearings with a heavy fit.
    Jul 2007
    No Cal.
    All good info guys - thank you very much
    Honestly the .002" came from another website that deals with these bearing quite a bit. But now that you have me checking with SKF's website I am thoroughly confused
    They actually only have Tolerance charts of cast iron or steel housings. This is going to be 6061 Al. Thought I would take a look at the charts any way and that is when it really got confusing
    Being the bearing has a 34mm outside diameter it recommended the IT6 fit from this chart for Cast Iron housings
    http://www.skf.com/pages/jsp/catalog...id=tcm:21-6532
    So is that um for micrometer on the interference side
    So if I'm reading this right it is .000016mm interference fit ?
    Mar 2009
    Ohio
    I get approximately .0006" press fit which in my opinion would be more that adequate. Or make it a slip fit with Loctite primer and Loctite.
    Primer is a must for aluminum.
    Toolznthings
    Woodinville, WA
    The chainsaws I deal with are 1.5 thou interference for about 1.375 diameter bearing. Heat the housing, drop in the bearing. Done.
    Surface finish is a big factor in interference "fit". I'd be happy with 0.002 on a 64mm bearing, but what is the bearing clearance class? I wouldn't do that with a C2.
