Originally Posted by
6PTsocket
If you check a safety glove chart you will not see lacquer thinner because it is blend of chemicals. Using the Kleenstrip SDS, for example, it is nine different chemicals. Different glove materials vary in their effectiveness against different chemicals. The SDS did give a rather weak recommendation for nitrile, saying it "may offer some protection". The Ansell site was more informative and says the chemical mix will even overpower nitrile after short exposure. They make a special laminated glove called a barrier glove but the down side is that it is fragile and if it must endure much abraison they reccomend using it as a liner under another of their gloves that is more durable. Their site is the best I have found for dealing with this problem.
Sent from my SM-G900V using Tapatalk
