Page 37 of 38 FirstFirst ... 2735363738 LastLast
Results 361 to 370 of 372
Thread: Rockerblock I.C.--Something a little different-
  1. #361
    Oct 2005
    British Columbia
    Brian if you are looking for a proof of concept test fuel have you considered starting fluid?
    Compared to gasoline that has a lower and upper threshold level of combustion ranging from 1.4-7.6% by volume of air, and propane at 2.1-10.1%, starting fluid is in the range of 1.9 to upwards of 48% by volume to air depending on the formulation. Irregardless of the formulation at hand it will always be more easier to achieve a combustible mixture using starting fluid temporarily. The window of opportunity will be much larger for a successful start.
    Good luck, she's a beauty!
    Home,down in the valley behind the Red Angus
  2. #362
    Feb 2016
    Edmonton, Alberta, Canada
    Brian already had it working on gas. He's just having some trouble getting it to run on propane.
  3. #363
    Jun 2004
    N.J.
    Maybe I missed it in the last 100 or so posts....
    At what point did you prove that your demand regulator was opening and allowing propane into the engine?
    Similarly, how have you tested that your engine is producing sufficient vacuum to open the demand regulator?
  4. #364
    Jan 2004
    Missouri
    Yes that.
    Finger over the intake should pull enough when turning over to get it to pop when finger is removed (see one of the links). Dribbling propane at carb should also, just to prove it fires on propane ok.
    Then the propane adapter can be fiddled with.
    Dec 2009
    Stevens Point, WI
    Quote Originally Posted by brian Rupnow View Post
    No Andy, I haven't tried that, because the propane will continue to flow while the engine is on compression, power, and exhaust strokes, flooding the room with propane and creating a fire hazard. I will probably end up in "The hot place" sooner or later, but I don't want to rush it.
    It would be a nice quick test just to see if the engine will run on propane like it should.
    Mar 2008
    Barrie, Ontario, Canada
    After my failed attempt to even have the engine fire on Propane fuel, I was beginning to wonder if perhaps the ignition timing or valve timing had "slipped" from the original settings where it ran so well on naptha gas. I had a spare gas tank setting around, so I installed it on the engine, and without readjusting anything the engine fired right up and ran well. I decided to have a 40 minute "endurance run", and about half way thru the run I picked up my camera and shot a short video. That explains the nasty oil on everything.---I had given all of the bearing surfaces a good squirt of lubricating oil and filled the water reservoir before starting the run. The water stays in the reservoir with no problem, but the oil quickly turns black and splashes all over the place.---Brian
    https://www.youtube.com/watch?v=dp0CgAwvBss
    Dec 2009
    Stevens Point, WI
    With it running on gas, could you just start to trickle in some propane and slowly shut off the gas till it is running on strait propane?
    Mar 2008
    I have a few people around the world building this engine now, and I am being asked about setting the valve timing. The set screws in the cams are difficult to access. I covered how I did this back on post #271, but here is a repeat of the way I did it. I was very lucky and the very first setting I used seems to work fine.
    --There is a bit of trickery involved in setting the valve timing. You must have the cylinder head and lifters and rockers all in place, and have the valve lash set at about 0.010" when the lifters are not "up" on the cams. I sawcut a 0.030" slot in the end of the camshaft that is on the same side as the cam gear, so that I could turn the camshaft with a screwdriver. I removed the flywheel on the side where the timing gears are and turned the other flywheel in the direction I intended the engine to run (clockwise when viewed from the side with the gears on.) The set screws in the exhaust cam were tightened at any random spot by reaching up through the bottom of the engine. The intake cam was left loose on the shaft. The setscrews in the cam gear were left loose. The crankshaft gear was tightened on the crankshaft at any random position. I turned the flywheel until the piston was about 40 degrees or so before bottom dead center, then used a screwdriver to turn the camshaft in the opposite direction to the crankshaft until the cam lobe was just beginning to influence the exhaust valve. At that point, I tightened the camshaft gear setscrews. That "locked in" the exhaust valve timing. I then kept turning the flywheel until the piston was about 30 degrees before top dead center. At that point I reached up through the bottom of the engine (with great difficulty) and rotated the intake cam until it was just beginning to influence the intake valve, then I locked it in place. The cam set screws are "accessible" either through the underside of the engine or through the vertical slots in the "bolster" which stiffens the cylinder head plate. If you simply can not get at the screws for the intake side cam, you can remove the other flywheel, the ignition cam, and the entire sideplate to get to the intake cam set-screws to tighten them. .---Brian
    Mar 2008
    Gee Whiz--I'm going international in a big way. The second Rockerblock engine ever built was just finished by DavidLloyd2 in New Zealand. Cogsy in Australia has a set of the plans, and a fellow in the U.K. also has a set. I just sold a set of plans to a fellow in Spain. I'm pretty sure I sold a set to someone in USA but I'm not certain---can't remember. David Lloyd2 in New Zealand has posted a video of his Rockerblock running on HMEM, and I think his actually runs better than mine.---Brian
    Nov 2010
    Portland Oregon
    Hi Brian,
    How are you offering your drawings for the engines you design? You say you have sold a few of this engine, are you offering any of your other projects up for sale. Might be interested in one of the simpler ones for a first timer.
    If you have a site could you post a link? Look forward to what you might have available.
    TX
    Mr fixit for the family
    Chris
